Configuring the Inter-Digit Timer
The inter-digit timer is used to configure the amount of time the phone waits after each digit is dialled before it assumes the user has finished entering digits and automatically sends the dialled number. This only applies whilst the phone is already off the hook. This setting needs to be configured on the phone. This article explains how to do this on the phones supported by 3CX Phone System.
Configuring the Inter-Digit Timer for Cisco SPA
  1. Start up the phone and identify its IP address – using the Setup key on the phone, go to “Network” >”Select”.
  2. Enter the phone’s IP address into the web browser to bring up the phones administration page.
  3. Select Admin “Login” > “Advanced”.
  4. Once in the advanced administration page select “Voice” > “Regional”
  5. Scroll down the page to the “Control Timer Values (sec)” section.
  6. Set the desired value for “Interdigit Short Timer” and click “Submit All Changes”. Wait for the phone to update its configuration.
Configuring the Inter-Digit Timer with Yealink
  1. Start up the phone and identify its IP address by navigating to “Menu” > “Status”.
  2. Enter the phones IP address into the web browser to bring up the phones interface page.
  3. Enter Username and Password (both “admin” by default).
  4. Click “Phone” > “Features” > Expand “General Information”
  5. In the “Inter Digit Time” set the desired value.
  6. Click “Confirm” at the bottom of the page. Wait for the phone to update its configuration.
Configuring the Inter-Digit Timer with Polycom
  1. Identify the phone’s IP address by pressing the menu key on the phone. Go to “Status” > “Network” > “TCP/IP Parameters”.
  2. Point your browser to the web interface of the phone.
  3. Enter Username and Password (By default, the username is “Polycom” and password is “456”)
  4. In the web interface, select “SIP”.
    Polycom - Digitmap
  5. Locate the “Digitmap” option. Polycom phones makes use of digit maps as defined in RFC 3435. A good explanation of Polycom digit maps can be found here. You would need to locate the matching option (which is separated by |) and configure the corresponding Digitmap (inter-digit) Timeout. In our example, we would like to change the timeout for the third matching option.
    Polycom - Digitmap Timeout
  6. The Digitmap Timeout setting is located directly under the Digitmap setting. In our case, we would need to change the third Digitmap Timeout option to the desired number of seconds.
  7. After customizing the digitmap Timeout, select Submit and wait for the phone to update its configuration.
Configuring the Inter-digit Timer with Snom
  1. Start up the phone and identify its IP Address – using the Setup key on the phone, navigate to “Menu” > “Maintenance” > “System Info”.
  3. In the web interface, select “Advanced” > “Behavior”.
  4. Enter the administrator login (Default: 0000).
  5. Locate the “Auto Dial” feature and from the drop down menu, select the desired option.
  6. Click “Apply”.
Liked this article?
Get notified of new articles
or share
You might also be interested in:
  1. This is excellent, thanks. Can one edit the provisioning templates of Yealink phones to include the desired inter-digit timeout parameter? It would be a serious task to do this manually on all extensions.
    November 12, 2012 at 10:47 am
  2. mixig
    This option is already in template, search this section in template:
    #[ ADVANCED ]
    #path = /config/voip/sipAccount0.cfg
    #default_t1 = 0.5
    #default_t2 = 4
    #default_t4 = 5
    November 12, 2012 at 1:25 pm
