How to Disable SIP ALG on Netgear Routers
SIP ALG is used to try and avoid configuring Static NAT on a router. Its implementation, however, varies from one router to another, often making it difficult to inter-operate a router with SIP ALG enabled with a PBX. In general, you would want to disable SIP ALG and configure one to one port mapping on the router.
In this article, we will show you how to disable SIP ALG on a Netgear router. SIP ALG on this router is known to cause problems with VoIP calls.
Follow this step-by-step guide:
Option 1:
  1. Open the Netgear router configuration by browsing to its LAN Address (http://192.168.0.1 by default).
  2. Log in to the router’s configuration. The default username is “admin” and the default password is “password”.
    Netgear WAN Setup
  3. In the main menu, select “Advanced” > “WAN Setup”.
  4. Enable the option “Disable SIP ALG”.
  5. Click “Apply”.
Option 2:
    2016-09-05_16h49_00
  3. In the main menu, select “Security” > “Firewall” > Advanced.
  4. Uncheck the option “Enable SIP ALG”.
  5. Click “Apply”.
Notes
Liked this article?
Get notified of new articles
or share
You might also be interested in:
  1. Still have problems with remote users. Waiting till day remote users work consistently. Especially today with so many apple and android users.
    October 13, 2012 at 12:42 am
    • @Keith – remote users already work consistently. However it would be good to check what the problem is in your case.
      October 15, 2012 at 1:28 pm
  2. Nicholas Sciberras
    @Keith, try using the procedure to troubleshoot remote extensions. You will be able to better identify the source of the problem.
    October 15, 2012 at 2:04 pm
