December 7, 2011 – 6:58 pm | 16 Comments
3CX is pleased to announce a new release of 3CX Phone System 10, build 22686. Service Pack 5 fixes numerous 3CX Wallboard issues and also adds a new and important caller ID feature. To download …
Read the full story »
Releases
3CX Product Releases
VoIP How To
Technical tips to run your VoIP PBX more efficiently
Events
3CX Trainings and Webinars around the world
Docs & FAQ
3CX Documentation how to and FAQ
Phone configuration
3CX, Aastra, Cisco, Yealink, Grandstream, Polycom configs
Home » Docs & FAQ
How to extend the inter digit timeout
Submitted by on June 10, 2009 – 8:59 pmNo Comment
It is possible for a user to make an outbound call via the Voicemail menu.
Dial 999 -> Enter PIN -> Press 9 (for options) -> Press 3 (to dial an external number) -> Dial external number.
When dialing the outbound number if no digits are entered for more than 1.5 seconds (1500ms) the PBX will assume the number is complete and start the outward dialing process.
To extend this timeout value, browse to “C:\Documents and Settings\All Users\Application Data\3CX\Data\Http\Interface\Ivr” (Windows XP/2003) or “C:\ProgramData\3CX\Data\Http\Interface\Ivr” (Windows Vista/2008), open the file called “VmailMenu.vxml”, and locate the lines:
<form id=”formDialOut”>
<var name=”external”/>
<field name=”fldDial”>
…and immediately after those lines, insert a new line:
<property name=”interdigittimeout” value=”5000″/>
This will set the inter-digit timeout to 5000 milliseconds (5 seconds).
Now you should save the changes and restart the 3CX Phone System service.
Comments are closed.
