December 7, 2011 – 6:58 pm | 16 Comments
3CX is pleased to announce a new release of 3CX Phone System 10, build 22686. Service Pack 5 fixes numerous 3CX Wallboard issues and also adds a new and important caller ID feature. To download …
Read the full story »
Releases
3CX Product Releases
VoIP How To
Technical tips to run your VoIP PBX more efficiently
Events
3CX Trainings and Webinars around the world
Docs & FAQ
3CX Documentation how to and FAQ
Phone configuration
3CX, Aastra, Cisco, Yealink, Grandstream, Polycom configs
Home » Docs & FAQ
Management and Myphone Web Interfaces show blank
Submitted by on January 2, 2010 – 6:28 pmNo Comment
This document describes how to resolve an issue when you try and access the 3CX Management Console or the 3CX MyPhone Portal and instead of getting the standard login screen, you see a blank white screen and “Done” on the lower left status bar of Internet Explorer browser window.
This happens occasionally on Server 2008 operating systems with Internet Explorer as the default browser because the cache is corrupted. It can happen after the 3CX Wizard completes and launches the 3CX Management Console Login Screen.
    The above screenshot shows the problem – Here we can see that the management console login screen was not loaded properly.
    Resolution:
    To resolve this simply press the F5 key to refresh the page.  You might get a popup with the following message:
    “Are you sure you want to navigate away from this page?
    null
    Press OK to continue, or Cancel to stay on the current page.”
    You can safely ignore this message and press OK.  After this the 3CX Login Screen will show correctly.
    Comments are closed.
