December 7, 2011 – 6:58 pm | 16 Comments
3CX is pleased to announce a new release of 3CX Phone System 10, build 22686. Service Pack 5 fixes numerous 3CX Wallboard issues and also adds a new and important caller ID feature. To download …
Read the full story »
Releases
3CX Product Releases
VoIP How To
Technical tips to run your VoIP PBX more efficiently
Events
3CX Trainings and Webinars around the world
Docs & FAQ
3CX Documentation how to and FAQ
Phone configuration
3CX, Aastra, Cisco, Yealink, Grandstream, Polycom configs
Home » Docs & FAQ
Jittery IVR when using HyperV or Vmware
Submitted by on March 11, 2010 – 3:42 pmNo Comment
When using a virtualized operating system and 3CX Phone System, you may experience Stuttering voice quality if you have not configured your virtual environment correctly. This article explains how pm timers on the machine may affect hyper v or vmware instances in which the guest os is Windows XP or server 2003.
Scenario – Hyper V installation with XP or 2003 guest operating system
Problem – In these operating systems, you may encounter a situation where the IVR music files being played have jittery or bad audio. To resolve this problem:
Limit your configuration to 1 virtual processor
Limit the configuration to use 1 virtual processor in Hyper V Settings, Processor, and set the number of logical processors to 1.
If you require 2 virtual processors
You will have to modify the Boot.ini file to use the /usepmtimer switch. To do this:
  1. Log on to the computer with an account that has administrative credentials.
  2. Click Start, click Run, type notepad c:\boot.ini, and then click OK.
  3. In the Boot.ini file, navigate to the line that starts with “default” in the “[boot loader]” section. This line specifies the location of the default operating system, for example:
    default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
  4. In the “[operating systems]” section, locate the line for the operating system that corresponds to the “default” line. For example, if the computer is running Microsoft Windows Server 2003, Enterprise x64 Edition, the line should resemble the following:
    multi(0)disk(0)rdisk(0)partition(2)\WINDOWS=”Windows Server 2003 Enterprise x64 Edition” /fastdetect /NoExecute=OptIn
  5. At the end of the line, add a space, and then type /usepmtimer. The line should now resemble the following.
    multi(0)disk(0)rdisk(0)partition(2)\WINDOWS=”Windows Server 2003 Enterprise x64 Edition” /fastdetect /NoExecute=OptIn /usepmtimer
  6. Save the file, and restart the computer.
The following is a sample Boot.ini file for a system that contains the /usepmtimer switch.
[boot loader]
timeout=0
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Windows Server 2003 Enterprise x64 Edition" /fastdetect /NoExecute=OptIn /usepmtimer
Comments are closed.
