Integrate your 3CX PBX with Vtiger CRM and increase staff productivityYes, you read correctly! We have added yet another CRM integration to the list of out of the box integrated CRMs that come with 3CX V15 PRO. Just like all the other integrations we have brought to you in the last two months this one is also straightforward and super-easy! By choosing to integrate your PBX with your CRM application you achieve increased productivity in addition to the following:
  • Call with Hot Keys – Use the 3CX Hot Key funtionality and initiate calls directly from your Vtiger CRM (read more about using Hot Keys)
  • Call Pop-ups – The customer record is brought up to you automatically during a call
  • Call Journals – Calls are logged as call records in the CRM
  • Create a new contact automatically when a call is received from an unknown number
So go ahead and read the Vtiger CRM Integration guide and see for yourself just how easy it really is.
The 3CX Plugins are available from within the Management Console under the Updates tab.
3CX also integrates with other CRM systems which can be found here. If your CRM is not in the list you can develop your own plugin, more information here.
