Manually Configuring a Multicast Paging Ring Group to work with Yealink T20, T22, T26, T28
Be aware that different firmware versions may have different web interface formats and functionality. For further support, please visit Yealink here
From 3CX Phone System
Ring groups can be used to facilitate multicast paging. Note that 3CX Phone System facilitates multicast paging along the address range: – and port range which is not already in use by 3CX Phone System.
create paging groupTo create a paging ring group:
  1. From the 3CX Phone Management Console menu, select “Add” > “Ring group”.
  2. Enter the ring group options:
    • Virtual Extension Number – This number identifies the ring group from other extensions. Keep the extension number automatically generated, or specify a new one as needed.
    • Name –Enter a name for the ring group.
    • Ring strategy – Select “Paging”.
  3. Enable the option “Use Multicast for Paging”.
  4. From the “Multicast options for paging” section:
    • IP Address of multicast channel – Add an address along the IP range: – (For example: Keep record this IP address as you will need it later on.
    • Port of multicast channel – Enter the port for the multicast channel (For example: 10000). Keep record this port as you will need it later on.
    • Codec – Select a codec for the multicast transmission. This codec should be supported by the phones receiving the multicast.
    • Packet time in milliseconds – Leave default or specify as needed.
  5. Click “Apply” followed by “OK”.
From Yealink Phone Interface
  1. Start up the phone and identify its IP Address – press the “Menu” key on the phone, and select the “Status” option. For this example we will assume the IP Address of the phone is, and IP Address of the 3CX Phone System machine is
  2. Point your browser to the web interface of the phone:
  3. Enter the phone’s login username (default “admin”) and password (default “admin”).
    Configure MulitCast Settings in Yealink
  4. Click on the “Contacts” tab > “MulticastIP”.
    • 1 IP Address – Enter the IP address configured in the Ring Group along with port as follows: <Multicast Address>:<Port>
    • Label – Enter the name of the ring group to which the IP address is configured.
  5. Click the “Confirm” button.
Note: The Yealink interface allows you to configure up to 10 multicast addresses, thus the Yealink can be set to listen for up to 10 multicast streams.
Liked this article?
Get notified of new articles
or share
You might also be interested in:
  1. Craig
    this does not appear to be available on the current t38/t32 firmware 3x.70.0.80
    October 25, 2012 at 5:31 am
  2. Craig
    Here is the template code for T38.
    [ cfg:/phone/config/vpPhone/MulticastPage.cfg ]
    ListenAddress1.Label = PAGE
    ListenAddress1.IPAddress =
    audio.PayloadType= PCMU
    ReceivePriority.Active = 0 #Barge
    ReceivePriority.Priority = 0 #0=Disabled, or 1-10
    October 25, 2012 at 5:34 am
  3. Kevin
    @Craig: Yealink Support confirms that the 70 series of firmware does not contain Multicast paging support. They have indicated that very probably the 71 series WILL contain this functionality.
    October 29, 2012 at 1:55 pm
