Caller information on your desktop
Zero Admin
With the new Dashboard
Bulletproof Security
With SSL certs and NGINX
Install on $150 Appliance
Intel MiniPC architecture
New, Intuitive Windows Client
More themes, more UC
More CRM Integrations
Scripting Interface to add your own
Improved Integrated Web Conferencing
iOS and Android apps included
Personal Click2Meet URLs
Caller Information on your Desktop for Incoming Calls
If you have the 3CX Desktop Components or the 3CX CRM Integration Module installed, 3CX MyPhone will automatically try to match the caller ID of an inbound call to a customer record. If it finds a match, it will open the customer record automatically. When a contact is not found in Microsoft Outlook or your CRM package, you can automatically create it by clicking the “Click to create a new contact record” link.
Contact information (Outlook or CRM package)
When an inbound call arrives to your extension, depending on your configuration, a screen pop-up is automatically shown, containing the related contact information that has been retrieved from your CRM.
Caller info
The screen pop-up can be manually closed at any time, or you can leave it to be automatically closed by the application if you have configured it that way.
You may automatically open the contact record in your CRM by selecting the “Click to open the contact record” link.
When a contact is not found in your CRM, you can choose to create it. To do this, click the “Click to create a new contact record” link. The following form will be displayed, and you will be able to fill the contact information.
Caller info
You may choose to create the contact in any enabled CRM. Pressing the “Create Contact” button, the application will try to create the contact and will notify you about the result.
Contact information (Skype)
In order to make the CRM Integration module work with Skype contacts, you need to store them with the “skype:” prefix. For example, if you have a contact with Skype ID “MyContactSkypeId”, you need to store it as “skype:MyContactSkypeId”. When the 3CX CRM Integration module detects that prefix, it does not remove non digit characters when making outbound calls, so the call can be made using the Skype ID.
Also, inbound calls from Skype contacts are matched using the “skype” prefix, so the screen pop-up will show the right information in those cases too.
