Make, receive and transfer calls using 3CX Phone for Android
Zero Admin
With the new Dashboard
Bulletproof Security
With SSL certs and NGINX
Install on $150 Appliance
Intel MiniPC architecture
New, Intuitive Windows Client
More themes, more UC
More CRM Integrations
Scripting Interface to add your own
Improved Integrated Web Conferencing
iOS and Android apps included
Personal Click2Meet URLs
Make, Receive and Transfer Calls using 3CX Phone for Android
Making calls using 3CX Phone for Android
Androind - making calls
To make a call, dial the number you want to connect to using the 3CXPhone dial pad. Tap the Dial button (the green button which displays a phone handset). Tap the hang up button (red button) to end the call.
Receiving calls using 3CX Phone for Android
Android - receiving calls
Upon receiving a new call, 3CX Phone for Android will ring. If the application is running in the background, bring it to front. At this point you are presented with the caller details. Tap the green button which displays a handset to answer the call. Tap the hang up button (red button) to end the call.
Transferring calls using 3CX Phone for Android
Whilst on an active call, perform the following steps in order to transfer a call.
Android - Transfer calls
  1. Tap the transfer soft key, located at the bottom right of phone.(the caller will be put on hold)
  2. Enter the number you want to transfer the call to.
  3. Tap the Dial button (the green button) to transfer the call.
  4. Once the receiving end of the transfer answers the call, the transfer will be completed.
