Provisioning a Panasonic KX-TGP500B01 DECT Phone
Enter Provisioning URL via the Panasonic web interface
Supported Models: Panasonic KX-TGP500B01
Ideally you will have the Panasonic phones pick up the HTTP server information using a DHCP Server with configurable Option 66. If this is not possible, then you can enter the information manually in the web UI of the phone using the procedure outlined below:
Configuring the provisioning server via the Panasonic KX-TGP500B01 web interface:
Step 1: Obtain the provisioning URL
Step 2: Enter the Information into the Web Interface of the device
See also
For a complete step by step guide to provisioning the Panasonic TGP 500 base for use with 3CX see the general configuration guide of Provisioning of Panasonic TGP500.”
Note: This guide was tested with the Panasonic firmware listed in the main provisioning guide. Other firmware versions might not have this functionality and will not be tested.
  1. Open the extension where the phone was provisioned to and and take a copy of the provisioning URL:
  1. Open the web interface of your Panasonic base station as described in the main guide and navigate to “Maintenance”  “Provisioning Maintenance.”
  2. Set the “Standard File URL” and enter the “Provisioning Link” taken before and press “Save.”
  1. The device will provision after a few seconds to the loaded configuration.
See also
Liked this article?
Get notified of new articles
or share
You might also be interested in:
  1. Frank
    I am using a TGP500 and running 3CXPS v10, but there is no Panasonic KT-TGP500 in the model drop down list.
    Where can I find the template?
    August 7, 2012 at 3:50 am
    • @Frank – its only available in version 11. You need to upgrade to get the support.
      August 7, 2012 at 12:37 pm
