Upgrading the Firmware of Yealink phones from the 3CX Management Console
In this article we will explain how you can upgrade the firmware of one or more Yealink phones within your network using the Firmware Update feature from within the 3CX Management console. In this example we upgrade a Yealink T46G to the latest firmware.
Prerequisites
phone node
  1. Log into the 3CX Management console and click on the Phones node.yealink 2
  2. Select the Yealink phone for which you want to upgrade the firmware (in this example, we selected the Yealink T46G) and click on the Upgrade Firmware button. Note that you can upgrade the firmware of multiple phones at the same time, however ensure that the firmware matches ALL THE PHONES you select.
  3. An Upgrade Firmware dialog will show with the phones and the firmware version that the Yealink phone will be updated to.
  4. Select the check-box next to the phone that you want to update the firmware to and click the Upgrade button.yealink 3
  5. A progress dialog will appear showing the download status of the firmware files.yealink 4
  6. Once the file download is completed press Finish to complete the firmware updating. The Yealink phone will reboot and will load the firmware from the 3CX Web server on boot-up.
Related articles and FAQ:
Liked this article?
Get notified of new articles
or share
You might also be interested in:
  1. Pingback: 3CX VoIP blog » IP Phone firmware upgrade with 3CX Phone System SP4
  2. Igor Snezhko
    Also noticed that this method simply doesnot work. The phone rebooting, but firmware is not loaded.
    Other people report the same problem.
    December 7, 2010 at 11:54 pm
  3. Andy Waters
    We have tried using this feature with yealink T28/22P phone’s and doesn’t seem to work as mentioned above, sure you guy’s are aware.
    December 16, 2010 at 11:48 pm
