3CX Phone System v10 Update for 3CX MyPhone
3CX Phone System Update 3CX is pleased to announce an update for 3CX Phone System Version 10. This update mainly focuses on 3CX MyPhone. To download this update, simply login to the 3CX Windows Management Console and it will be available under the “3CX Phone System Updates” node.
New Features
  • Added description of profile in drop-down status (Available, away etc)
  • Drag and drop
  • Spanish and Simplified Chinese language updates
  • Added search box filter in phonebook
  • Terminal services support *
Bugs Fixed
  • Fixed issues in extension sorting
  • Call control operations are now displayed under the 3CX Logo
  • Fixed bug in deleting of voicemails from the Voice Mail tab
  • Fixed bug in conference calls
  • Fixed bug in Listen, Listen and whisper and barge in operations
  • Call history error when displaying a lot of calls
  • Bug in changing of language
  • Outlook detection and proper VSTOR installed
  • Calls from Outlook will strip dashes and spaces-Requires Desktop Components update
  • Issue in Outbound rules in dialing section fixed with blank prefixes and priority
  • Extensions that are part of MANAGEMENT group can delete company phonebook entries
Known Issues
  • *Terminal Server setup: Since TAPI is not multi user aware, Outbound calls using TAPI will not work and will always call the first extension that connects to the TAPI service. The context menu “Call Contact” in Outlook still appears. We will remove this in a later update. Uninstall previous assistant and install 3CX Desktop Components on the domain\administrator account.
  • When 3CX MyPhone is updated, a clear of cache is sometimes required.
Important Notice
To update 3CX MyPhone is simple. After the administrator has updated 3CX Phone System from the winforms management console, users can click on 3CX MyPhone shortcut on their desktop. A message will inform the user that 3CX MyPhone has been updated. Restart the application.
3CX Desktop Components has been also updated. Click to watch the Installing Desktop Components video tutorial on the 3CX YouTube Channel.
Please post any questions about this release to the 3CX Phone System V10 forum.
Use this V10 Demo Key to activate enterprise features: LFMD-4QDR-7OHP-ZZO2
We look forward to your feedback!
Liked this article?
Get notified of new articles
or share
You might also be interested in:
  1. Many Thanks, this is a big help as it was a pain trying to guess what buttons do by its colour.
    We just need another bug fixing now, and that is the Call Back Feature within call queues.
    when enabled it says internal error
    May 20, 2011 at 10:43 pm
  2. Pingback: 3CX Phone System v10 Update for 3CX MyPhone | Tekouse
  3. Bruce Kreeger
    Nice job 3CX team. Update took less than five minutes including restarted services and updating the MyPhone application.
    May 21, 2011 at 8:36 pm
  4. CSX
    Yes, nice job but can we expect french translation pretty soon ?
    May 22, 2011 at 2:53 am
  5. Renato
    To me it´s impossible mark the check box to update!!!
    Renato P
    May 24, 2011 at 12:15 am
  6. Brown Nose in NJ
    Terrific job 3CX. Another great releae. Sorry I brown-nosed too late and the KING arrived before me.
    May 24, 2011 at 1:17 am
  7. Bluetel
    nice work, myphone use very less memory and cpu rather than assistant. others feature add are intereting too.
    May 25, 2011 at 8:04 pm
  8. Geert
    Renato, use the system management console and not the webinterface element. Now you can select the update select box.
    May 28, 2011 at 10:56 pm
  9. Rene
    TAPI %callerid% will not set correctly if the call go to the queue alwys says 800 is calling instead of the external Caller Number
    May 29, 2011 at 5:11 pm
  10. Ajibola Olayemi
    When will windows interface for the 3cx be out only andriod users are making good use of it.
    June 1, 2011 at 2:14 am
