3CX Phone System v10 Release Candidate
3CX Business Phone System Version 103CX is pleased to announce a Release Candidate for 3CX Phone System Version 10. This build fixes many issues and also adds some features that were missing in previous versions of V10.
Features Added
  • Play Voicemail locally without play on phone (requires 3CX desktop Components)
  • Trigger call using HTTP CTI URL. More information here
  • Bring to front with/without stealing of focus
  • Ability to log and agent in or out from all queues from the 3CX MyPhone Portal
  • Queue statistics (available in Call Center Edition only)
  • Added description of extension state and forwarding rules in MyPhone so all company users are aware of their forwarding rules configuration
  • Save position and size of 3CX MyPhone after exit. (requires 3CX Desktop Components and single monitor)
  • Multiple delete of voicemails from 3CX MyPhone Voicemail tab
  • Performance improvements in 3CX MyPhone
  • 3CX MyPhone Application starts up automatically and has option to remove from startup
  • Queues tab can see active queue calls and depending on rights perform operations on the Queue call (Pickup,transfer,divert)
  • Transfer and Divert dialog can now transfer by typing in the company / phonebook name. A dropdown will appear with all the matched entries
  • Plug and Play feature detects the appropriate phone and selects the according template for that phone depending on user agent received. Works for 3CX Phone for Windows and Grandstream
  • Added automatical download of .NET Framework in 3CX Phone System installation
  • 3CX Phone for windows provisioning of blf keys. Requires new 3CX Phone for Windows V6
  • Support for VoIP Providers that have a non-resolvable sip server but a valid and resolvable outbound proxy
  • Outbound rules configured to allow specific groups containing extensions with ring my mobile simultaneousy are allowed external calling automatically
Bugs Fixed
  • Hotkey fixes
  • Extension sorting by name (first/last) or extension numbers
  • Remember me – MyPhone now remembers login credentials (Clear of cache might be required)
  • Improved 3CX Desktop Components detection and operations
  • Improved timing issues in the 3CX MyPhone for call duration
  • Tapi integration fixes – Make and disconnect calls from outlook dialing interface
  • Profile changing bug fixed
  • Journalling in Outlook integration
  • Double incoming notifications in Outlook contact popup records
  • Polycom Phonebook directory fixes
  • Fixed proper VSTOR detection for all verions of Outlook on all architectures 32 and 63 bit
  • Sound notifications in chat, chat extension blocking
Known Issues
  • Extension calling an external number and then performing a transfer might result in a wrong notification in the 3CX MyPhone
  • Some calls might show with an incorrect duration if MyPhone is not already logged in.
  • After Desktop components is installed, user needs to start 3CX MyPhone Installed Locally manually
IMPORTANT
The provisioning port has changed to port 5000. This means that you must change the provisioning links for the phones to “http://IPADDRESSSERVER:5000/provisioning”. You can do this via DHCP option 66 or by configuring the phones from their web interface. See the configuration guides for more information. Reboot the phones after you have made this change.
3CX Desktop Components has been also updated. Click to watch Installing Desktop Components on YouTube.
  1. Upgrading 3CX Phone System RC on the server, will also include the latest 3CX Desktop Components instalation file.
  2. If you have 3CX MyPhone Installed locally on the client machines simply double-click them. You will see a silverlight message popup notification informing you that the application has been updated and needs a restart. Proceed with the restart of the 3CX MyPhone Silverlight application. Upon restart 3CX MyPhone will be updated from Beta to RC.
  3. Log in, navigate to Settings tab and click on Preferences
  4. Click on the INSTALL Button. The latest version of 3CX Desktop components will be installed locally. Double click on the installer and follow the installation instructions.
  5. Once the 3CX Desktop components have been installed, double click on 3CX MyPhone Application on your desktop. Your 3CX MyPhone application is fully updated.
Downloads
Please post any questions about the beta to the 3CX Phone System V10 beta forum here.
Use this V10 Demo Key to activate enterprise features: LFMD-4QDR-7OHP-ZZO2
We look forward to your feedback!
Liked this article?
Get notified of new articles
or share
You might also be interested in:
  1. Igor Snezhko
    Thanks!
    Link on 3CXPhone 6 is absent.
    April 23, 2011 at 5:56 pm
  2. Pingback: 3CX VoIP Blog » 3CX Phone System v10 Release Candidate
  3. Pingback: 3CX VoIP TK Anlage Blog » 3CX Phone System v10 Release Candidate
  4. Pingback: 3CX VoIP Blog » 3CX Phone System v10 Release Candidate
  5. Pingback: 3CX VoIP Blog » 3CX Phone System v10 Release Candidate
  6. Bruce G. Kreeger
    Nice job 3CX Developers. We are loading Ver. 10 RC and running with it effective immediately. Hopefully Ver. 10 will be released before the end of the month. Happy Easter to all who celebrate!
    April 24, 2011 at 7:08 am
  7. Claudio
    Always apply the HTTP API of version 9?
    In Version 9 when Abyss web server is used, the links should look like the example below
    link-http://:5481/ivr/PbxAPI.aspx?func=upd_ext&ext_num=&pwd=&disable_external=0
    link-http://:5481/ivr/PbxAPI.aspx?func=make_call&from=&to=&pin=
    April 24, 2011 at 5:15 pm
  8. @Claudio – No the port has changed to 5000 now. All 3CX Websites in both IIS and ABYSS webserver installations have all their websites on port 5000. So simply change 5481 to 5000 and it will work. Thanks
    April 25, 2011 at 5:03 pm
  9. Brian Mills
    I cannot get this to work, I have a GXP 2100 with phone provisioning enable, it gets it ssettings OK from the tftp server but I get:
    SIP request (REGISTER) from 89.0.9.113 was rejected. Reason: Block WAN requests is ON.
    .in the server event log and also:
    Authentication failed for SipReq: REGISTER 89.0.9.8 tid=1260901722 cseq=REGISTER contact=103@89.0.9.113:5060 / 2017 from(wire); Reason: Credentials don’t match, check that authorization-ID and password match the ones in extension settings
    … in the server activitylog.
    April 26, 2011 at 4:09 pm
  10. Brian Mills
    Actually this is fixed by turning OFF the option in Extension > Other > Disallow use of extensuion outside the LAN. But the 3CX and the grandstream are on the same lan and subnet?
    April 26, 2011 at 4:17 pm
  11. @Brian – the 3CX and the grandstream seem to be on the same lan and subnet yes but this happens to not be a LAN. It is a WAN. From what I see it is trying to register from external location. “Block WAN requests is ON.” This happens because from what I see 89.0.9.X is not a local ip address scope. Can you confirm this pls?
    April 27, 2011 at 1:54 pm
  12. Wladimir
    Brian Mills to accept your problen you must use the 3CX Tunnel in account settings ! and write ip:local ip of remove BPX….I spend 2 hours to accept this problem
    May 7, 2011 at 7:19 am
  13. Lee
    Change from Ver 9 to 10 went smoothly. Removed 9 and attempted to install 10 without a reboot. It didn’t like that as load failed saying that port 5000 was already in use. A PC reboot solved that issue. So far so good.
    May 8, 2011 at 12:26 pm
  14. @lee
    Did you see a message from the installer prompting you to reboot?
    May 8, 2011 at 1:23 pm
  15. Running on 10 RC2 now.
    Tested on Cisco / Polycom / GrandStream.
    Love the new email alert feature! Merci 3CX!
    May 12, 2011 at 11:50 pm
    • @Olivier – Thanks for the nice feedback! :)
      May 13, 2011 at 1:15 pm
