December 7, 2011 – 6:58 pm | 16 Comments
3CX is pleased to announce a new release of 3CX Phone System 10, build 22686. Service Pack 5 fixes numerous 3CX Wallboard issues and also adds a new and important caller ID feature. To download …
Read the full story »
Releases
3CX Product Releases
VoIP How To
Technical tips to run your VoIP PBX more efficiently
Events
3CX Trainings and Webinars around the world
Docs & FAQ
3CX Documentation how to and FAQ
Phone configuration
3CX, Aastra, Cisco, Yealink, Grandstream, Polycom configs
Home » Releases
3CX Phone System v7 beta available!
Submitted by on October 30, 2008 – 4:56 pmOne Comment
After 2 alpha releases, the beta is now available. We are almost done :-) Here is what has been fixed & added:
Note: Close the management console BEFORE making a restore. After a restore you need to restart the application pool in IIS (Run Inetmgr, and restart 3CX application pool)
Fixed: My phone website not found after backup and restore from 6 to 7
Fixed: DID range creation and updating in Inbound rules page
Fixed: Firefox 3 browser is now able to upload files
Fixed: Bug in Append ring group/Queue name
Fixed: Incorrect notification in Http API for call recording
Fixed: Problem with using external numbers in Ring Groups
Fixed: Paths for IVR and Prompts after a restore from Version 6
Fixed: You can add DID’s with 3 digits using masks
Fixed: Generic Trunks set not to register would register anyway
Fixed: Bug in Specific and Out of Specific Hours
Fixed: Bug in Restart All services
Fixed: Download and selection of prompts from the systems prompts.
Fixed: Session ID was being shared between the Myphone and Management console
Added: Implemented checking for Configuration service port 5485
Added: Ability to change port of configuration server from ini file
Added: New section – Global options
Added: Ability to append Call Queue or Ring Group name after caller ID
Added: Re-arranged Admin Credential Page
Added: source identification by DID
Added: mask matching for DID’s (exact, start and end)
Added: source identification for gateways in ‘to’ field by default
Added: Generate support info in Backup and restore tool and in Help interface.
Added: changes to Phone functionality in templates
Removed: DID importing from Version 6 to 7. These need to be recreated
You can download 3CX Phone System for Windows Beta from here.
You can download the 3CX VoIP client for v7 here
Looking forward to your feedback! Please use the special beta forums here
One Comment »
  • [...] Read more:  3CX Phone System v7 beta available! [...]
