3CX Voice Application Designer Version 3 Build 3821 Available
3CX is pleased to announce a new release of 3CX Voice Application Designer, version 3, build number 3821, designed to work with 3CX Phone System 11. This new version includes bug fixes, improvements and new features such as the ability to play audio generated with Text to Speech and the ability to create a deployment package.
Download 3CX Voice Application Designer here. You can view the 3CX VAD User Manual here.
New Features:
  • New VAD function “REPLACE”, allows replacing text with another text.
  • New VAD function “REPLACE_REG_EXP”, allows replacing text matching a regexp with another text.
  • Text to speech functionality using Microsoft Speech APIs.
  • Create Deployment Package functionality.
  • The EMailSenderComponent leaves the server credentials empty when they are not specified.
  • License activation issue: when activating a 3CX VAD key on the same PC where 3CX Phone System is installed, it will no longer change 3CX Phone System to the free edition. This fix now requires that the VAD is launched with admin privileges.
  • Record component now supports saving a file using absolute paths.
  • E-mail sender component now supports sending attachments using absolute paths.
  • File management component now supports using files with absolute paths.
  • Now the URI property in the WebInteraction Component is an expression, so it can be dynamically created.
  • Now the URI and WebServiceName properties in the WebServicesInteraction Component are expressions, so they can be dynamically created.
  • Project file version moved from 1.0 to 1.1 and added automatic changes to WebInteraction and WebServicesInteraction components in order to treat current values as constant string expressions.
  • The Expression Editor now shows help about VAD function fields.
Please post any questions and comments about this release to the 3CX VAD Forums. A detailed build history can be found here.
We look forward to your feedback!
Liked this article?
Get notified of new articles
or share
You might also be interested in:
  1. Bruce G. Kreeger
    The 3CX Development Team has done it again!
    July 20, 2012 at 7:44 am
    • Hi Bruce, thank you so much for the heads up!
      July 22, 2012 at 1:44 am
  2. smile
    hi, any demo license for VAD11 ?
    July 24, 2012 at 9:18 pm
  3. smile
    sorry VAD3
    July 24, 2012 at 9:27 pm
  4. Hash
    While upgrading from VAD2 to VAD3 there are some licesne issues.
    My existing license is not working.
    It says successfull registration but then another popup says
    ” An Error occured …….. License\VADLicense.bin: Error Licence: 64 System 0.
    What could be the issue?
    If I re-install VAD2 all works fine.
    Any help appreciated.
    July 29, 2012 at 6:31 pm
