3CX Voice Application Designer, Build 3679
3CX Voice Application Designer - New Build Available3CX is pleased to announce a new release of the Voice Application Designer, build number 3679. This new version includes bug fixes and improvements, including the ability to play audio files generating the file name with an expression.
The new installer can be downloaded from here. The new user’s manual can be downloaded from here.
Change Log – 3CX Voice Application Designer, Build 3679
Fixes:
  • Problem when sending boolean parameters to a .NET library object using an External Code Execution component.
  • Problem when deploying projects to a 3CX Phone System installation with no tenants (invalid PbxVersion).
  • License activation now sends the country code instead of the country name.
  • Problem with drag and drop of some components.
New Features:
  • Default PBX version is 3CX Phone System 10.
  • Ability to configure prompts with dynamically generated file names (using expressions).
  • Better logs when an error occurs on server side execution.
You can view the complete build history here. We welcome your comments and reviews on this new build.
Liked this article?
Get notified of new articles
or share
You might also be interested in:
  1. This is great, just one question does it matter if expression used is in French ?
    July 29, 2011 at 11:28 pm
  2. Ernesto Dos Santos Afonso
    The expression is a JavaScript expression. You can use the expression editor to easily create it.
    August 2, 2011 at 4:05 am
  3. Are the error logs automatically notified to a supplied email address or in the log itself for manual checking?
    August 3, 2011 at 11:41 pm
  4. Ernesto Dos Santos Afonso
    Runtime error logs from the VAD application are located in the application folder. For example %ProgramData%\3CX\Data\Http\Interface\ivr\YourProject.
    August 11, 2011 at 6:35 pm
