New Version of 3CXPhone for Android App Available (1.2.11)
New Build of 3CXPhone for AndroidWe are proud to announce the latest 3CXPhone for Android app release, build 1.2.11. This build adds support for Android versions 2.3, 3.0 and 3.1 as well as some new features. It also includes some fixes to improve the stability and performance of the application.
This version was tested with the following Android phones:
  • HTC Wildfire S : Android 2.3.3
  • HTC Wildfire : Android 2.2
  • HTC Desire : Android 2.2
  • Samsung GT-I9100 : Android 2.3.3
  • Samsung GT-I9000 : Android 2.2
  • Sony Ericsson Xperia U20i : Android 2.1
  • Sony Ericsson Xperia X10i : Android 2.0
  • Motorola XOOM : Android 3.1
  • Motorola Milestone XT720 : Android 2.1.1
  • HTC EVO 4G : Android 2.3
  • Asus Transformer HC : Android 3.1
Fixes
  • Auto-provisioning
  • Wrong proxy handling when using internal server
  • Crash of application on incoming call when call recording is enabled
  • Better handling of internal and external server options
New
  • Support for Android 2.3, 3.0 and 3.1
  • Authentication ID support that can be different from extension number for increased security
  • Caller ID (display name)
  • TCP functionality (Beta)
Known Issues:
  • Changing SIP Port to other than 5060 will not work properly at the moment
  • On some phones, there may be a noticeable amount of noise or echo in SpeakerPhone Mode
A detailed build history of 3CXPhone for Android can be found here.
Please post any questions about this release to the 3CXPhone for Android Forums.
We look forward for your feedback!
Liked this article?
Get notified of new articles
or share
You might also be interested in:
  1. What’s the deal with the Droid X?
    June 16, 2011 at 7:44 pm
  2. Bruce Kreeger
    Hopefully Droid-X will get supported soon too!
    June 16, 2011 at 4:58 pm
  3. Will not install ON Motorola Xoom Android Honeycomb 3.1.
    This is the error when I try to install:
    “Purchase cancelled, 3CXPhone for Android (VoIP)
    Your device is not compatible with this item.”
    June 18, 2011 at 8:24 am
  4. Nicky
    @Bob Specifically for Motorola Xoom use this link
    link-http://www.3cx.com/downloads/3CXPhone.apk
    @JShelley Droid X is unsupported.
    June 20, 2011 at 7:28 pm
  5. Saiful
    It would be better to have tunnel options available for all 3CX mobile dialers. In many countries port 5060 is blocked, therfore tunnel is required to work around blockage. Please include it in next release for Android & iPhones dialers.
    June 28, 2011 at 2:37 am
  6. DIIDIIER
    COMO SE LLENA LA BENTANA QWE APARECE PARA PODER ENTRAR QWE DIC CONNECTION CETTINGS
    June 29, 2011 at 9:45 am
  7. @Saiful – Yes the tunnel is super useful. Unfortunately this is easier said than done. We will have it but not in the next release. This is not some notepad or diary application we are doing here.
    @DIIDIIER – You want to know how to fill in the order or what exactly? You need to post this in english or else in the appropriate blog. If you want to control the order of the connection settings, then this is not possible and not needed too. You have a list and you scroll to the connection you need. We do not see why you need to have them in order.
    June 29, 2011 at 1:35 pm
  8. ELIAS
    Not work on GT-i5800 samsung
    June 29, 2011 at 7:19 pm
  9. Gil-more
    Works good on my Samsung Transform with Android 2.2.2
    Thanks!
    July 1, 2011 at 10:21 pm
  10. would I want to use my PC (Win7) to make phone calls to others’ landline phones?
    July 4, 2011 at 6:16 pm
  11. @Elias
    Samsung GT-I5800 is not supported. The reason is following: we tested 3CXPhone with this model and it don’t register, at least on WiFi. A network capture revealed nothing being sent from the device. Quite interesting, on another WiFi network it worked normally. We suspect it might be a matter of different WiFi encryption but, until things are not clear, we consider this model as unsupported.
    July 6, 2011 at 2:02 am
  12. i got problem setting up 3cx phone on the moto defy can u help
    July 7, 2011 at 3:05 pm
  13. QC
    why I cannot record calls? In the older version, I can record calls in my Google Nexus One. Now after new version of 3cxphone in my cellphone, I cannot record calls. Why? Can you see my post here? Pls help.
    July 8, 2011 at 4:35 am
  14. Jose
    I have problems with HTC Desire S. It doesn´t register. Is it supported ?.
    July 14, 2011 at 6:37 pm
