The BETA release of 3CX v15 is available for download today! The final release is scheduled for the 6th of July, and we can't wait.
In this release we have included the new Windows client with a brand new interface. We’ve made it much more modern and UC friendly, with more emphasis on the presence screen. For the BETA we have only included one theme but there will be more exciting, never before seen, themes to follow!
Improved Web Conferencing
With v15 we’ve set to bring web conferencing to the core of the PBX. We’ve redesigned the interface to make it much more intuitive and user friendly and we’ve also included an Android app for users to be able to join meetings on the go, talk about complete mobility!
The Android app supports Android versions 4.4 and up and gives you the ability to see up to four connected video streaming participants.
Main Fixes
- Added call history converter to convert call logs from v12.5 to v15.
- Improved updates functionality - download updates using HTTPS, all new updates are accounted for.
- Increased the 3CX Tunnel security and made numerous fixes for socket control and better audio delivery.
Still pending and not included in this BETA:
- Easy configuration of FXS Gateways
- Easy configuration of DECT base stations & handsets
- Extension level rights
- Bulk extension editing
- Ability to run VAD scripts
- New SBC build to follow shortly
- iOS 3CX WebMeeting app
3CX Mac and Windows clients will be automatically updated to work with v15. V14 Android and iOS clients work with v15.
Download links and Documentation:
Download 3CX v15 from this form – be sure to enter your details correctly, you will be sent a licence key that is required for setup.
IMPORTANT: Partners & Customers that already have commercial/nfr licence keys must use their existing key during installation. You can evaluate with a another key, but be sure to leave your subdomain of choice free so it will be linked to the key that you will be using. Do not link your subdomain of choice to a free key (unless you intend to use that).
NOTE: If you have already installed the ALPHA you will need to uninstall and re-install this BETA.
Download the 3CX WebMeeting Android app here.
View the complete change log for 3CX Phone System.
View the 3CX client for Windows change log.
Admin Manual:
- Introduction & Installation
- Extension / Endpoint Management
- Trunk Management
- System Management
- PBX Services
We’re eager to hear what you think! Please post your feedback on our forum or as a comment below.
