• Releases
    3CX Product Releases
  • VoIP How To
    Technical tips to run your VoIP PBX more efficiently
  • Events
    3CX Trainings and Webinars around the world
  • Docs & FAQs
    3CX Documentation how to and FAQ
  • Phone configuration
    3CX, Aastra, Cisco, Yealink, Grandstream, Polycom configs
Configuring IP Phone LCD Display language with 3CX Phone System
By December 2, 2010 | 10 Comments
3CX Phone System features the ability to easily change your IP Phone’s LCD display language network wide or on a per phone basis. Pre-requisites
  • Download & install the available language packs for your phone model – Not all models require Language packs.
  • It is recommended to use 3CX Tested firmwares – not all firmwares support language display changes
  • 3CXPhone System Version 9 SP4 and later is required
After you have installed the appropriate language packs (follow links below for instructions specific to your phone), you can select the preferred phone display language in the Extensions ‘Phone Provisioning’ tab.  The restart the phone.
  • Yealink – Supported languages are included in the firmware, select preferred display language and restart phone
  • Aastra phones -Install language packs according to this procedure
  • Cisco/Linksys – Install language packs according to this procedure
  • Grandstream – Install language packs according to this procedure
  • Polycom phones – changing of display language is not supported
Comment 10
  • [...] articles and FAQ: Provision Aastra phones, Change LCD Display languages, Aastra manual [...]
  • [...] Excerpt from: IP Phone LCD Display language with 3CX SP4 [...]
  • [...] Changing the LCD Display language [...]
  • [...] Changing the LCD Display languages on Cisco / Linksys phones [...]
  • [...] Change LCD Display languages, [...]
  • [...] Originally posted here: Configuring IP Phone LCD Display language with 3CX SP4 [...]
  • [...] See the article here: Configuring IP Phone LCD Display language with 3CX SP4 [...]
  • [...] Visit link: Configuring IP Phone LCD Display language with 3CX SP4 [...]
Switch to our mobile site
