Implement QoS for 3CX VoIP on Debian Linux
If you need QoS on your Debian Linux system, this step-by-step guide shows how to create a rule for iptables that tags all traffic from the machine with a higher QoS so as to ensure traffic is given priority.
Step 1: Making sure your QoS rules are applied permanently to your system
By default, your Debian Linux system will NOT save any rules applied at runtime. This can however be resolved by adding the iptables-persistent package to your installation as follows:
apt-get install iptables-persistent
This will create a new file in “/etc/iptabes/rules.v4” that will be loaded at each system and service restart.
Step 2: Create a Rule to Tag All Traffic Originating From This Machine
Run the following commands at the command prompt:
iptables -t mangle -A OUTPUT -p udp -j DSCP –set-dscp 56
iptables -t mangle -A OUTPUT -p tcp -j DSCP –set-dscp 56
Step 3: Checking QoS is Applied to Outbound Traffic
Use tcpdump to create a network capture file for you to examine using Wireshark on some other computer:
tcpdump -s 0 -w 247-check-dscp.pcap
Download this file onto your PC, and open it with Wireshark. You can check that outbound traffic is indeed being tagged with the correct DSCP value:
Step 4: Make Sure the Changes are Saved Permanently
iptables-save >/etc/iptables/rules.v4
Liked this article?
Get notified of new articles
or share
You might also be interested in:
Leave a Reply
    • Kevin Attard Compagno
      Thanks @Orlin
      January 4, 2017 at 5:04 pm
