December 7, 2011 – 6:58 pm | 16 Comments
3CX is pleased to announce a new release of 3CX Phone System 10, build 22686. Service Pack 5 fixes numerous 3CX Wallboard issues and also adds a new and important caller ID feature. To download …
Read the full story »
Releases
3CX Product Releases
VoIP How To
Technical tips to run your VoIP PBX more efficiently
Events
3CX Trainings and Webinars around the world
Docs & FAQ
3CX Documentation how to and FAQ
Phone configuration
3CX, Aastra, Cisco, Yealink, Grandstream, Polycom configs
Home » VoIP How To
STUN and VoIP – part 1
Submitted by on January 9, 2009 – 7:55 pm2 Comments
STUN stands for Simple Traversal of User Datagram Protocol (UDP) through Network Address Translators (NAT’s). It is used in several different network implementations and scenarios, one of which is VoIP. Because of the way protocols used in a SIP based VoIP call work, making calls between two SIP entities running behind NAT devices such as a router or firewall, users typically encounter problems. Examples are one way audio during a phone call or phone registration failures when trying to register to a VoIP provider or a IP PBX not residing on the same network. STUN is a protocol that helps in resolving problems. Read the full article here.
2 Comments »
  • Monali says:
    Does 3CX phonesystem come with an inbuilt STUN Server?
  • Nick Galea says:
    There is no need for a PBX to have a STUN server. The stun server is separate and only useful when located outside the LAN.
