December 7, 2011 – 6:58 pm | 16 Comments
3CX is pleased to announce a new release of 3CX Phone System 10, build 22686. Service Pack 5 fixes numerous 3CX Wallboard issues and also adds a new and important caller ID feature. To download …
Read the full story »
Releases
3CX Product Releases
VoIP How To
Technical tips to run your VoIP PBX more efficiently
Events
3CX Trainings and Webinars around the world
Docs & FAQ
3CX Documentation how to and FAQ
Phone configuration
3CX, Aastra, Cisco, Yealink, Grandstream, Polycom configs
Home » VoIP How To
The STUN Protocol and VoIP – Part 2
Submitted by on September 9, 2009 – 8:15 pmOne Comment
As seen in Part 1 of this article, STUN enables a SIP entity running behind a NAT to discover its public IP and what type of NAT is running on the gateway it is connected to. It also enables the SIP entity to discover which port external SIP entities can connect to, to establish a connection. Since SIP uses UDP as transport protocol, and UDP is not a connection oriented protocol, a connection between 2 SIP entities cannot be established easily by depending on the transport protocol, that is why STUN is widely used in a SIP based VoIP environment. Below we are going to see captures of a SIP based VoIP phone trying to register to an IP PBX running outside its network and what happens if the SIP based VoIP phone is using STUN protocol or not.
Sending of a SIP message without using STUN protocol
Below is a capture of a SIP Register message; a SIP based VoIP phone running behind a NAT trying to register as extension 101 with an IP PBX (listening on host name voipproducts.org) running outside its network without using STUN protocol.
REGISTER sip:voipproducts.org SIP/2.0
Via: SIP/2.0/UDP 192.168.2.14:7214;branch=z9hG4bK-d8754z;rport
Max-Forwards: 70
Contact: : <sip:101@192.168.2.14:7214;rinstance=0639bae5043c66ac>
To: “account1″ <sip:101@voipproducts.org>
From: “account1″<sip:101@voipproducts.org>;tag=0a75d76e
Call-ID: OTcxMDU5MGNhNTAxNzgzYjZkODVkY2I3MmE3NDhlNzQ.
CSeq: 1 REGISTER
Expires: 3600
Content-Length: 0
From the above we can see that:
Contact: <sip:101@192.168.2.14:7214;rinstance=0639bae5043c66ac>
In the “Contact” field we can see that the SIP based VoIP phone is specifying its own private IP address (192.168.2.14) and port 7214. Therefore it is requesting the remote IP PBX outside its network to try to establish a connection by sending SIP messages back to IP address 192.168.2.14 and port 7214. In such case, the IP PBX will try to establish the connection but since this is a private IP address, it is not routable on the internet and therefore the response the IP PBX tries to send is usually dropped by a router or internet gateway. Since packets are dropped, the connection cannot be established.
STUN resolution explained
If a SIP based VoIP phone has STUN resolution enabled and a STUN server specified, the VoIP phone sends a STUN resolution request to the STUN server and waits for the STUN server to reply. Such request typically is done during startup of the VoIP phone or before trying to communicate with an external SIP entity. Below is a capture of a typical STUN server response:
Message Type: Binding Response(0×0101)
Message Length: 0×0044
Message Transaction ID: E753D76EA857A24DA38A229F7576E18E
Attribute: MAPPED-ADDRESS
Attribute Type: MAPPED-ADDRESS(0×0001)
Attribute Length: 8
Protocol Family: IPv4 (0×0001)
Port: 6023
IP: 78.158.143.115 (78.158.143.115)
Attribute: SOURCE-ADDRESS
Attribute Type: SOURCE-ADDRESS(0×0004)
Attribute Length: 8
Port: 3478
IP: 10.252.131.113 (10.252.131.113)
Attribute: CHANGED-ADDRESS
Attribute Type: CHANGED-ADDRESS(0×0005)
Attribute Length: 8
Port: 3479
IP: 75.101.138.128 (75.101.138.128)
Message type: This field states the message type; in the above example we can see that this is a Binding response to the Binding request sent to the STUN server by the VoIP phone.
Message Length: This field states the message length in bytes.
Message Transaction: This is a unique identifier used for each STUN message binding / response session. For each new transaction, a new unique identifier is created.
Attribute Length: 8
Port: 6023
The above attribute is called “MAPPED-ADDRESS”; its purpose is to indicate the source IP (from the above example; 78.158.143.115) and source Port (from the above example; 6023) the server saw in the Binding request sent from the SIP based VoIP phone.
Attribute Length: 8
Port: 3478
The above attribute is called “SOURCE-ADDRESS”; its purpose is to indicate if twice NAT configurations are being used. From the above we can see that twice NAT configuration is being used because the VoIP phone’s IP address is 192.168.2.14, the public IP from where the Binding request was received is 78.158.143.115 and the IP address from where the last point which contacted the STUN server received the STUN request was 10.252.131.113.
Attribute Length: 8
Port: 3479
The above attribute is called “CHANGED-ADDRESS”; its purpose is to indicate the IP address and port where the response would have been sent from if the client requests a “Change IP” and “Change Port” in a “CHANGE-REQUEST” attribute.
Sending of a SIP message using STUN protocol
Below is a capture of a SIP Register message; a SIP based VoIP phone running behind a NAT trying to register as extension 101 with an IP PBX (listening on host name voipproducts.org) running outside its network using STUN protocol.
Max-Forwards: 70
Contact: <sip:101@78.158.143.115:8676;rinstance=c82d2f5b1918e5cf>
To: “account1″<sip:101@voipproducts.org.com>
From: “account1″<sip:101@voipproducts.org>;tag=484b4e36
Call-ID: YWI3Y2I3ODIzOWIxYWI5NDQwMzA5ZTYxMTAzOTM4Y2I.
CSeq: 1 REGISTER
Expires: 3600
Content-Length: 0
The VoIP client is still listening on the same internal IP address (192.168.2.14) and same port (7214).
In the “Contact” field in the register SIP message the VoIP phone replaces its own IP address (192.168.1.14) with the external IP address (78.158.143.115) and external Port (8676) discovered by making a STUN resolution before trying to register with an external IP PBX. Thanks to the STUN resolution, now the IP PBX can establish a connection with the VoIP phone by sending SIP responses to IP address 78.158.143.115 on port 8676 which is mapped to IP address 192.168.2.14 and port 7214 on the NAT device.
As seen above, since most of the protocols used in SIP based VoIP calls typically use UDP as transport protocol, which is a connectionless protocol, STUN plays a very important role in aiding SIP entities running behind NATs establishing a SIP based VoIP call.
One Comment »
  • [...] host tries to connect to an external host, STUN is not a good solution for such a scenario. In our next article we will see sample capture of STUN requests from VoIP devices and will explain how it helps in [...]
