PLEASE NOTE: This blog post is only applicable for 3CX Phone System v12.5 and lower.
3CX Phone System includes functionality to easily set the Time Zone and DST (Daylight Savings Time) parameters on phones via provisioning. By default, 3CX Phone System is configured for US Eastern Time. You can manage Time Zone settings from the 3CX Management Console in the "Settings->Phone Provisioning" page.
Time Server
Alternatively, you can set this to some internal FQDN or IP Address. Please refer to this article for further details: https://www.3cx.com/blog/docs/windows-sntp-ntp-server/
Time Zone for the Different Models
For each of the different provision-able phone brands, you can select the appropriate Time Zone value from the drop-downs. The example above is for US Mountain Time.
If your Time Zone requires Daylight Savings Time to be configured, check the "Enable Daylight Savings Time" option, and specify the dates when DST starts and ends. The "Offset" field default value of 60 minutes is valid for most time zones. The example above shows the DST settings for US Mountain Time in 2011.
