How to Check Your Voicemail using Cisco 7940/7941/7960/7961
In this example we will demonstrate how to check your voicemail using Cisco 7961. This procedure stands for Cisco 7940/7941/7960/7961.
Checking Your Voicemail
voicemail cisco 7940 7941 7960 7961
  • To check your voicemail, press the “Messages” button and follow the voice prompts. You might need to enter your voicemail PIN number followed by # to listen to your message.
For additional information on managing your voicemail from your IP Phone, such as the numbers you need to dial to change or update settings, read your detailed guide.
Liked this article?
Get notified of new articles
or share
You might also be interested in:
