In this example we will demonstrate how to check your voicemail using Fanvil C62 and C58. Fanvil phones support CTI Mode.
Checking Your Voicemail
When your extension receives a voicemail, the "Message" button on your phone will light up.
- To listen to your voicemail, press the "Message" button then the "Dial" button and follow the voice prompts. You might need to enter your voicemail PIN number followed by # to listen to your message.
