With 3CX Phone System Multi Tenant, you can host up to ten instances of 3CX Phone System in the cloud and offer it as a service for your customers to generate recurring profitable income.
Benefits of 3CX Phone System Multi Tenant:
- Each instance is independent from the other, with it’s own 3CX Management Console
- Works on 64-bit architecture such as Windows 7, Windows Server 2008 / R2
- Deploy updates selectively and tailor individual licenses
- Easy backup and restoration of each PBX instance
- Each tenant uses approximately only 200MB
How to get 3CX Phone System Multi Tenant
To obtain 3CX Phone System Multi Tenant, please contact the 3CX Sales Team. For additional general technical information on 3CX Phone System Multi Tenant, click here. Information on installing 3CX Phone System Multi Tenant can be found here and the port list here.
Yes, this is the official release of 3CX Phone System Multi Tenant.
Kind regards,
Jaymes
YOu can also contact portech to see what options are needed – (maybe there is something misconfigured)
Otherwise, well done 3CX, thanks for looking after your Partners.
Every tenant will have his own set of ports. 3CX MyPhone and phone provisioning will work for each tenant on a respective set of ports. You can see a list of ports here: http://www.3cx.com/blog/support/3cx-multi-tenant-port-list
Regards,
Andrew
Pingback: 3CX VoIP blog » 3CX Announce Release of Cloud-Ready Version of 3CX Phone System
