Skype and 3CX
User to User - Answers are provided by the community. 3CX does NOT provide technical support via this forum. Commercial grade support should NOT be expected.
Moderators: agp, 3CX staff
New User
Skype and 3CX
Postby PCTurnkey » Fri Mar 30, 2012 11:03 pm
Skype connect seems to be WAY to pricey. Is there a way I can use my personal account, or setup the company's account to use Skype as the VoIP provider and have it just pull from Skype credit when routing outbound calls?
I've seen some Russian, 3rd party software that will connect Skype to 3CX, but I wanted to know if there is a straightforward way to do it.
3CX Valued Professional
Has thanked: 22 times
Been upvoted: 3 times
Re: Skype and 3CX
Postby leejor » Sat Mar 31, 2012 12:18 am
Not being one that uses a pay service with Skype, I'm not sure how that all works (what you can, and can't do).
However, you can connect to the "free" Skype (non-SIP) service using the 3CX Skype Gateway. I don't believe that it is "officially" supported any longer, but as long as you use an older version of Skype (see... ), then you should have no problem.
After you install Skype be sure to disable any automatic version updates.
New User
Re: Skype and 3CX
Postby jeinstei » Sat Mar 31, 2012 1:43 am
Excellent answer. If you want to do it yourself with a bit more work, siptosis gateway can be configured on any machine to provide a generic skype interface. It acts pretty much the same, but not as easy to use/install.
Return to “3CX Phone System - General”
Who is online
Users browsing this forum: No registered users and 2 guests
