Slider 2TryLearn MoreSlash your Phone bills - Slider Image
Use SIP trunks, WebRTC & Apps
Slash your Phone Bill by 80%
Provisioning a Panasonic KX-TGP500B01 DECT Phone
Enter Provisioning URL via the Panasonic web interface
On this topic
Supported Models: Panasonic KX-TGP500B01
Configuring the provisioning server via the Panasonic KX-TGP500B01 web interface:
Step 1: Obtain the provisioning URL
Step 2: Enter the Information into the Web Interface of the device
See also
Ideally you will have the Panasonic phones pick up the HTTP server information using a DHCP Server with configurable Option 66. If this is not possible, then you can enter the information manually in the web UI of the phone using the procedure outlined below.
For a complete step by step guide to provisioning the Panasonic TGP 500 base for use with 3CX see the general configuration guide of Provisioning of Panasonic TGP500.”
Note: This guide was tested with the Panasonic firmware listed in the main provisioning guide. Other firmware versions might not have this functionality and will not be tested.
  1. Open the extension where the phone was provisioned to and and take a copy of the provisioning URL:
  1. Open the web interface of your Panasonic base station as described in the main guide and navigate to “Maintenance”  “Provisioning Maintenance.”
  2. Set the “Standard File URL” and enter the “Provisioning Link” taken before and press “Save.”
  1. The device will provision after a few seconds to the loaded configuration.
See also
By |August 6th, 2012|Comments Off on Provisioning a Panasonic KX-TGP500B01 DECT Phone
Free for up to 1 year! Select preferred deployment:
On-Premise
for Linux on a $200 appliance or as a VM
Get the ISO
On-Premise
for Windows as a VM
Download the setup file
On the cloud
In your Google, Amazon, Azure account
Take the PBX Express
