Установка программы
Discussion in '3CX Phone System - General' started by mnemonix, Jan 14, 2008.
  1. mnemonix
    Jan 8, 2008
    13
    Возникает такая ошибка что делать стоит Windiws XP
    08:09:28.031 CallMgr::Initialize [CM000002] *!* Failed to initialize SIP stack!
    08:09:28.015 gt;>:Failed to create transport: V4 UDP 5060 on ANY
    08:09:28.015 gt;>:[ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] already in use
    08:09:28.015 CallMgr::Stack::Initialize [CM106000] ** Adding transports **
    08:09:27.968 CallMgr::Initialize [CM100003] ** Initializing SIP stack **
    08:09:27.968 CallMgr::Initialize [CM100002] Default Local IP address: 192.168.15.101:5060
    08:09:27.812 CallMgr::Initialize [CM100001] Version: 3.1.2434.0
    08:09:27.812 CallMgr::Initialize [CM100000] Start 3CX PhoneSystem Call Manager
    08:09:27.796 LoadLicenceInfo [CM100008] Licence loading error
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    You have something running on port 5060. Most probably it's some SIP phone. Port 5060 should be free prior to running 3CX PBX
