падает media server
mnemonix
09:34:27.906 StratInOut::eek:nHangUp [CM104007] Call(5): Call from Ext.100 to 74955077777 has been terminated by Ext.100; cause: CANCEL; from IP:192.168.15.100
09:33:25.593 CallConf::eek:nIncoming [CM103002] Call(5): Incoming call from 100 (Ext.100) to sip:[email protected]
09:31:02.015 StratInOut::eek:nHangUp [CM104007] Call(4): Call from Ext.102 to 74955077777 has been terminated by Ext.102; cause: CANCEL; from IP:192.168.15.101
09:30:44.359 CallConf::eek:nIncoming [CM103002] Call(4): Incoming call from 102 (Ext.102) to sip:[email protected]
09:30:37.796 StratInOut::eek:nHangUp [CM104007] Call(3): Call from Ext.102 to 74951690002 has been terminated by Ext.102; cause: CANCEL; from IP:192.168.15.101
09:30:10.421 CallConf::eek:nIncoming [CM103002] Call(3): Incoming call from 102 (Ext.102) to sip:[email protected]
09:30:02.656 StratInOut::eek:nHangUp [CM104007] Call(2): Call from Ext.102 to 74951690002 has been terminated by Ext.102; cause: CANCEL; from IP:192.168.15.101
09:29:24.171 CallConf::eek:nIncoming [CM103002] Call(2): Incoming call from 102 (Ext.102) to sip:[email protected]
09:28:42.000 StratLink::eek:nHangUp [CM104001] Call(1): Ext.102 hung up call; cause: BYE; from IP:192.168.15.101
09:28:31.031 CallLegImpl::eek:nConnected [CM103001] Call(1): Created audio channel for Ext.103 (217.15.51.96:16454) with third party (192.168.15.101:49154)
09:28:31.031 StratInOut::eek:nConnected [CM104005] Call(1): Setup completed for call from Ext.102 to Ext.103
09:28:31.031 CallLegImpl::eek:nConnected [CM103001] Call(1): Created audio channel for Ext.102 (192.168.15.101:49154) with third party (217.15.51.96:16454)
09:28:30.781 ListenDisconnect [CM114001] SL: disconnected KOP:0/MediaServer at [KOP]/MediaServer
09:28:30.421 CallConf::eek:nProvisional [CM103003] Call(1): Ext.103 is ringing
09:28:29.812 CallConf::eek:nIncoming [CM103002] Call(1): Incoming call from 102 (Ext.102) to sip:[email protected]
09:13:59.140 ListenConnect [CM114000] SL: connected KOP:0/PHPExtension_0 at [KOP]/PHPExtension_0
09:11:21.171 ServRegs::eek:nAdd [CM113002] Registered: Ext.101
09:11:14.406 ServRegs::eek:nAdd [CM113002] Registered: Ext.102
09:10:55.953 ServRegs::eek:nAdd [CM113002] Registered: Ext.103
09:10:36.171 ServRegs::eek:nAdd [CM113002] Registered: Ext.100
09:09:35.359 ClientRegs::eek:nSuccess [CM113005] Registration of sip:[email protected] is successful
09:09:35.312 ClientRegs::eek:nSuccess [CM113005] Registration of sip:[email protected] is successful
09:09:30.359 ExtLine::Register [CM110004] Send registration for <sip:[email protected]>
09:09:30.359 ExtLine::Register [CM110001] Use External IP for device line registration DN='10000' device='sipnet.ru'
09:09:30.046 StunClient::process [CM115002] STUN resolved external IP=217.15.51.96:5060 by server 64.69.76.23
09:09:29.843 ExtLine::Register [CM110004] Send registration for <sip:[email protected]>
09:09:29.843 ExtLine::Register [CM110001] Use External IP for device line registration DN='10000' device='sipnet.ru'
09:09:26.843 StunClient::process [CM115002] STUN resolved external IP=217.15.51.96:5060 by server 64.69.76.23
09:09:26.593 StunClient::process [CM115001] Send initial STUN request to 64.69.76.23
09:09:26.484 CallMgr::Stack::thread [CM106001] ** Enter Stack Loop **
09:09:25.265 ServRegs::checkExpiration [CM113000] Registration for sip:[email protected] has expired
09:09:25.234 ServRegs::checkExpiration [CM113000] Registration for sip:[email protected] has expired
09:09:25.203 ServRegs::checkExpiration [CM113000] Registration for sip:[email protected] has expired
09:09:25.187 ServRegs::checkExpiration [CM113000] Registration for sip:[email protected] has expired
09:09:25.171 CallMgr::DumThread::thread [CM100004] ** Enter DUM Thread **
09:09:24.296 IVRConnected [CM111000] IVR Server is connected
09:09:24.296 ListenConnect [CM114000] SL: connected KOP:5483/IVRServer at [KOP]/IVRServer
09:09:22.640 DBA [CM109000] ** Database connection Ok **
09:09:22.062 CallMgr::Stack::Initialize [CM106000] ** Adding transports **
09:09:22.015 CallMgr::Initialize [CM100003] ** Initializing SIP stack **
09:09:22.015 CallMgr::Initialize [CM100002] Default Local IP address: 192.168.15.100:5060
09:09:21.921 MediaServerConnected [CM112000] Media Server is connected
09:09:21.921 ListenConnect [CM114000] SL: connected KOP:0/MediaServer at [KOP]/MediaServer
09:09:21.921 ListenConnect [CM114000] SL: connected KOP:0/VoiceBoxManagerService at [KOP]/VoiceBoxManagerService
09:09:21.578 CallMgr::Initialize [CM100001] Version: 3.1.2434.0
09:09:21.578 CallMgr::Initialize [CM100000] Start 3CX PhoneSystem Call Manager
09:09:21.343 LoadLicenceInfo [CM100008] Licence loading error
Get 3CX - Absolutely Free!
3CX
