1.0.23 Dial-Button no function for outgoing calls
Discussion in 'iOS' started by pug1810, May 18, 2011.
  1. pug1810
    May 18, 2011
    I just dial a number with the dialpad and when i am pressing at the green Dial-Button, nothing happens.
    When i get a call and i press the green button everythings fine, i get my call.
    Device Info
    Phone Model: iphone
    Generation: 4
    Firmware Version: 4.3.3
    Jailbreak: YES
    Cydia Installed: YES
    Issue Info
    Handset: Phone
    Contacts: Local
    Connection: WiFi
    Server: External
  2. StefanW
    Jun 2, 2009
    1,236
    96
    When u press green is the app after kinda locked or do u can still add or del numbers?
  3. pug1810
    May 18, 2011
    i can edit and delete numbers. no problem doing this. also the button gets an blue border by pressing it. but nothing happens.
    and when i choose a number from the phonebook the number appears in the top, but there is no dial-button. i have first to click on "exit". then the last digit will be deleted ( just as i have pressed delete ) and the green button appears.
  4. pug1810
    May 18, 2011
    I solved it. When i enter the server into "Proxy" it works. Don´t know why, i´ve never to do this in other apps.
    For everyone with the same problem.
    Office-Net Central Phone alias Arcor Central-Phone
    Seetings:
    Use external server : OFF
    Internal Server: XXXXX.arcor-phone.de
    Externel Server :
    Server port: 5060
    STUN Server : XXXXX.arcor-phone.de
    Proxy: XXXXX.arcor-phone.de
    Thanks for the support. Very nice app.
