1.0.23 Outgoing calls wont work
Discussion in 'iOS' started by oliverm, May 12, 2011.
  1. oliverm
    Mar 10, 2009
    79
    i've set up the iphone app here at home (1.0.23) and have configured it for my office phone id and password. The idea being that when I am out of the office people can forward calls to my office extension and my iphone softphone will ring.
    I can receive incoming calls on the iphone but outgoing calls disconnect just before the first ring. THe server log shows this (ive changed any sensitive numbers);
    22:34:26.031 [CM503020]: Normal call termination. Reason: Not found
    22:34:26.031 [CM503016]: Call(3): Attempt to reach <sip:0207123123@110.239.76.251> failed. Reason: Not Found
    22:34:26.031 [CM503014]: Call(3): No known route to target: <sip:0207123123@110.239.76.251>
    22:34:26.031 [CM503010]: Making route(s) to <sip:0207123123@110.239.76.251>
    22:34:26.031 [MS210000] C:3.1:Offer received. RTP connection: 84.45.218.189:9000(9001)
    22:34:26.031 Remote SDP is set for legC:3.1
    22:34:26.031 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for iPhone 1.0.23] PBX contact: [sip:100@110.239.76.251:63864]
    22:34:26.031 [CM503001]: Call(3): Incoming call from Ext.100 to <sip:0207123123@110.239.76.251>
    22:34:25.922 [CM500002]: Info on incoming INVITE:
    INVITE sip:0207123123@110.239.76.251:5060 SIP/2.0
    Via: SIP/2.0/UDP 84.45.218.189:5060;rport=5060;branch=z9hG4bKPjFESlaM8gfTv35yQYdijsq6Lpj4HQkljW
    Max-Forwards: 70
    Contact: <sip:100@84.45.218.189:5060>
    To: <sip:0207123123@110.239.76.251>
    From: <sip:100@110.239.76.251>;tag=HYv2uYkGXIqeECTaEceVEDYToXstvyvn
    Call-ID: xg-D2E2TObYRoFp4b7xsjtvDrNT-iVCb
    CSeq: 7412 INVITE
    Session-Expires: 1800
    Min-SE: 90
    Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
    Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="414d535c03dce36133:2e01817f777d9aa602f99c111b5c2e7d",uri="sip:0207123123@110.239.76.251:5060",response="b420603a95b93e2b266bf333c5168d84",algorithm=MD5
    Supported: replaces, 100rel, timer, norefersub
    User-Agent: 3CXPhone for iPhone 1.0.23
    Content-Length: 0
    The only thing that stands out to me, and this may mean nothing, is that it's trying to connect to 0207123123@110.239.76.251, but thats the public IP, and the firewall wont allow access to the public IP from inside. However I dont have a normal call made from the office phones to compare this to.
    Any ideas what I've done wrong?
    Olly
  2. StefanW
    Jun 2, 2009
    1,199
    79
    so you are inside the lan in ur wifi? this log shows that the phone likes to connect to you from external (out of the office)
    there is a toogel in the settings where you have to say if your inside the office or outside the office...
  3. oliverm
    Mar 10, 2009
    79
    I was out of the office when doing that and the toggle was set to use the external server
  4. StefanW
    Jun 2, 2009
    1,199
    79
    can the number be dialied inside the network from another comuter like this: 0207123123
    Or do you must dial "0 0207123123" ??? Not found is the indication that the dest. is not found to route to...
  5. oliverm
    Mar 10, 2009
    79
    It happens if we autoprovision the soft phones (Windows and iPhone tried so far) internally as well. The number we are dialling exists and works from a physical handset.
    Here's the logs from trying to dial from an internal software phone.
    12:26:53.376 [CM503020]: Normal call termination. Reason: Not found
    12:26:53.376 [CM503016]: Call(142): Attempt to reach <sip:123456789@10.1.39.6> failed. Reason: Not Found
    12:26:53.376 [CM503014]: Call(142): No known route to target: <sip:123456789@10.1.39.6>
    12:26:53.376 [CM503010]: Making route(s) to <sip:123456789@10.1.39.6>
    12:26:53.376 [MS210000] C:142.1:Offer received. RTP connection: 10.1.39.30:4006(4007)
    12:26:53.376 Remote SDP is set for legC:142.1
    12:26:53.376 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for iPhone 1.0.23] PBX contact: [sip:100@10.1.39.6:5060]
    12:26:53.360 [CM503001]: Call(142): Incoming call from Ext.100 to <sip:123456789@10.1.39.6>
    12:26:53.360 [CM500002]: Info on incoming INVITE:
    INVITE sip:123456789@10.1.39.6:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.1.39.30:5060;rport=5060;branch=z9hG4bKPjDFGkp8xywQEPAchi5lUk2xneZfgmPgFN
    Max-Forwards: 70
    Contact: <sip:100@10.1.39.30:5060>
    To: <sip:123456789@10.1.39.6>
    From: <sip:100@10.1.39.6>;tag=r6OduSd.rdpsv4jXxmxTPLZaVijt1M1X
    Call-ID: SQywylXxlOgXYBtcHhPPQdZ8zj4.9eqo
    CSeq: 21050 INVITE
    Min-SE: 90
    Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="414d535c03e43dfd35:984c271b76e06c095e88722d4a842c03",uri="sip:123456789@10.1.39.6:5060",response="66c61b2f7fabcce37491e75038ad7f67",algorithm=MD5
    Content-Length: 0
  6. StefanW
    Jun 2, 2009
    1,199
    79
    you did not answered my question.
    both issues are the same "No known route to target: <sip:123456789@10.1.39.6>
    but does this matches your outbound rules of the pbx I dont think so...
  7. oliverm
    Mar 10, 2009
    79
    I see. You mean were we pressing 9 in front of the number :)
    That does appear to solve the issue. Which then leads us on to another problem. If we dial a number from the contacts of the iphone or android then we aren't given the chance to dial 9 in front of it, and if we put 9 infront of the number in the contact record itself then the iphone wont dial it when using anything other than 3cx.
    Does that make sense?
    Is there a solution? Something like telling 3cx to put a 9 infront if the call if made from a soft phone?
    Olly
  8. StefanW
    Jun 2, 2009
    1,199
    79
    no due to in the settings you see a phonebook prefix and a + converter to 00 so this is solved to
