1.0.23 SiP2SiP Not Registered
Discussion in 'iOS' started by jettechfsr, May 25, 2011.
  1. jettechfsr
    May 25, 2011
    6
    I just installed 3CX 1.0.23 and can't get it to register on sip2sip
    What should my Credentials ??
    Credentials
    User= Tried my user name both with XXX and xxx@sip2sip.info
    ID= Tried my user name both with XXX and xxx@sip2sip.info
    Password= tried my sip2sip password
    what should be the server settings?
    Server Settings
    User = SIP2SIP user ID XXX@sip2sip.info (I see everyone has a number I have a name)
    Password = my SIP2SIP password
    Internal Server = blank
    External Server = sip2sip.info
    Stun Server = stun.3cx.com & stun3.3cx.com (tried both)
    Proxy: Blank
    Device Info
    Phone Model: iPhone
    Generation: 3GS
    Firmware Version: 4.3.1
    Jailbreak: NO
    Cydia Installed: NO
    Issue Info
    Handset: Phone
    Contacts: Local
    Connection: [WiFi|3G]
    Server: [Internal|External]
  2. StefanW
    Jun 2, 2009
    1,199
    79
    Re: SiP2SiP Not Registered
    this should be clearly told by sip2sip but you may try to set sip2sip.info as well as proxy
  3. jettechfsr
    May 25, 2011
    6
    sip2sip wiki does not cover 3cx
    and adding the proxy did not fix the problem
  4. StefanW
    Jun 2, 2009
    1,199
    79
    but may they cover a sim. phone. Also may try with the 3CXPhone for Windows.
    http://www.3cx.com/downloads/3CXPhone6.msi
    Or try to bound the Provider to our PBX solution http://www.3cx.com/blog/releases/unified-communications-new-3cx-version-10/, where then the setup for the iphone app will be done automatically.
  5. jettechfsr
    May 25, 2011
    6
    Can someone just tell me what format to put my User Name and ID etc for this to work do you need to have @sip2sip.info or just the user name
  6. jettechfsr
    May 25, 2011
    6
    here is what I got from Sip2Sip
    Username: XXXXX (my USER name)
    - Domain/Realm: sip2sip.info
    - Outbound proxy: proxy.sipthor.net
    - XCAP root: https://xcap.sipthor.net/xcap-root
  7. StefanW
    Jun 2, 2009
    1,199
    79
    no, only sip2sip can do so
    I would start here. Also it is nothing we have tested our phone against due to it is not reachable from a normal land line..
  8. jettechfsr
    May 25, 2011
    6
    uninstaling app do to lack of support I asked many times what to put in what blocks and you could not do that
    will not recommend this app to anyone
  9. StefanW
    Jun 2, 2009
    1,199
    79
    First I have to set something strait.
    This is not a normal voip provider, we agree to this, second our phone is for free and as the topic is already telling, it is no tech support by 3cx for clients which not use a 3cx phone system nor have a support contract with us. So the tone here should be at all time friendly!
    I got my self an account and got is asap to work. Here my settings:
    I also changed my SIP Port to 5062, due to you and me have maybe more then one SIP Phone running!
    Understand there are alone in germany over 1000 VoIP Providers, we can not test them all and know how to set them up. The doc. by the provider should give a clear instruction!
  10. jettechfsr
    May 25, 2011
    6
    Ok fair enough that is what I needed!!!!!
    I had also missed proxy.xxx also
    Now works great looking forward to trying other products
    Was a tough road but we got there thanks for not just dropping this I'm sure will help others
    everyone likes free services :D
