1 DID with both voice + fax on it at the same time?
Discussion in '3CX Phone System - General' started by dapatter, Feb 18, 2010.
  1. dapatter
    Feb 17, 2010
    53
    Hi I have only one DID number, is it possible to have the system detect whether it is a voice call and route to vmail / phone or if it is a fax route to the fax server? doesnt look like you can do this from the inbound rules?
  2. sunstate
    sunstate Member
    Dec 16, 2009
    257
    I actually posted the same question earlier today, so if you find out the answer let me know. :)
    http://www.3cx.com/forums/pri-did-s-and-incoming-faxes-13817.html
    -Seth
