1 extension voicemail or foward stop working after update
Discussion in '3CX Phone System - General' started by 805tech, Dec 6, 2013.
  1. 805tech
    Aug 30, 2013
    39
    So far we found 1 remote extension voicemail and forwarding rule stopped working. I call the extension and it rings there but after 4 rings the phone says Not Acceptable and beeps 3 times and hangs up. I have even tried deleting the extension and recreating it. I looked at the log and this is what is says
    Leg L:1007.1[Extn] is terminated: Cause: BYE from PBX
    06-Dec-2013 11:20:33.845 Leg L:1007.2[Extn] is terminated: Cause: 302 Moved Temporarily/INVITE from 162.XXX.XXX.XXX:5065
    06-Dec-2013 11:20:33.845 [CM503003]: Call(C:1007): Call to <sip:360@68.XXX.XXX.XXX:5060> has failed; Cause: 302 Moved Temporarily/INVITE from 162.XXX.XXXX.XXX:5065
    06-Dec-2013 11:20:33.845 [CM503020]: Call(C:1007): Normal call termination. Call originator: Extn:358. Reason: Terminated
    06-Dec-2013 11:20:33.845 L:1007.1[Extn] failed to reach Extn:360, reason Redirected
    06-Dec-2013 11:20:33.845 [CM503014]: Call(C:1007): No known route from Extn:358 to target: <sip:805XXXXXXX@68.XXX.XXX.XXX:5060>
    06-Dec-2013 11:20:33.845 [Flow] Target endpoint for 805XXXXXXX can not be built!
    06-Dec-2013 11:20:33.845 [CM503006]: Call(C:1007): Diverted to: <sip:805XXXXXXX@68.XXX.XXX.XXX:5060>
    06-Dec-2013 11:20:33.844 Call to T:Extn:360@[Dev:sip:360@162.XXX.XXX.XXX:5065] from L:1007.1[Extn] failed, cause: Cause: 302 Moved Temporarily/INVITE from 162.XXX.XXX.XXX:5065
    06-Dec-2013 11:20:21.165 [CM503025]: Call(C:1007): Calling T:Extn:360@[Dev:sip:360@162.XXX.XXX.XXX:5065] for L:1007.1[Extn]
    06-Dec-2013 11:20:21.116 [CM503027]: Call(C:1007): From: Extn:358 ("Ceasar Martinez" <sip:358@192.168.XXX.XXX:5060>) to T:Extn:360@[Dev:sip:360@162.XXX.XXX.XXX:5065]
    06-Dec-2013 11:20:21.116 [CM503004]: Call(C:1007): Route 1: from L:1007.1[Extn] to T:Extn:360@[Dev:sip:360@162.XXX.XXX.XXX:5065]
    06-Dec-2013 11:20:21.115 [CM503001]: Call(C:1007): Incoming call from Extn:358 to <sip:360@192.168.XXX.XXX:5060>
    10,757
    286
    Re: 1 extension voicemail or foward stop working after updat
    Are you certain that our outbound rules allow a call from this extension to 805XXXXXXX, the log says NO.
    You fail to mention exactly what "update" you did? Operating System, 3CX version, etc....
  3. 805tech
    Aug 30, 2013
    39
    We have Server 2008 R2 and 3CX V12 and went from SP2 to SP3 on the update. And we have other setups that are exactly the same as this one and they work.
  4. leejor
    10,757
    286
    And does an outbound call dialled from extension 358 to 805XXXXXXX work?
  5. 805tech
    Aug 30, 2013
    39
    yes it does
