1 SIP account with many numbers
Discussion in '3CX Phone System - General' started by infotrust, Apr 1, 2010.
  1. infotrust
    Apr 1, 2010
    Hi there,
    Is there a way to link 4 different SIP numbers, from the same VOIP provider, to the 4 extention buttons on a Linksys SPA941? And then one can dial on that specific number/extention out...
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    If you mean linking the outbound caller ID, then it can only be set per extension, you cannot link multiple.
