1 trunk - 1HQ - 7 remote offices - 8 outbound numbers
Discussion in 'Ideas' started by Sharecom Dirk De Prest, Feb 28, 2017.
1 trunk - 1HQ - 7 remote offices - 8 outbound numbers 5 5 1votes
5/5, 1 vote
  1. Sharecom Dirk De Prest
    Feb 28, 2017
    I need the functionality to change my outbound number if I'm at one of the remote offices of in the HQ.
    Some representatives are driving around in the country and need to change the outbound number on the mobile 3CX APP so they do not confuse the customer.
    The easiest way is change of LAN IP-adres, that the outbound number change with it.
    If the APP detects a new IP-address range a pop-up comes up with the question what outbound number must be used.
    Or maybe with a prefix for each office
    Al the docs I see is with multiple Trunks and not all within 1 trunk.
    Regards
    Dirk
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    If 3CX doesn't get this into V15, we could write a monitoring service that looks at the IP where the phone is registered, and automatically change the caller ID number based on the IP. For 3CX phone for Windows, we could create a popup as described, and let you choose a new caller ID.
