1 VoIP line - 2 simultaneous calls
Discussion in '3CX Phone System - General' started by emerbrito, Oct 29, 2007.
  1. emerbrito
    Oct 24, 2007
    24
    I have a system set with 4 extensions and 1 VoIP line from broadvoice.
    Today i noticed that with this line, while i was making an external call, somebody called us and was transfered to another extension (by the Digital Receptionist).
    Is that normal? One line, one number and more than one simultaneous call? Broadvoice won't charge me more for that?
    I appreciate any comments.
    Thanks;
  2. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    It depends on your plan from your ITSP. I was under the impression that Broadvoice only allowed one call per line at a time. There are other providers who charge by the minute instead of by the month who do allow multiple simultaneous calls.
    One of them is nexVortex.
  3. emerbrito
    Oct 24, 2007
    24
    Is there a way to blok it (simultaneous calls on the same line) on the 3CX software?
  4. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    In the line setup page under other options- there is a setting for maximum simultaneous calls.
  5. emerbrito
    Oct 24, 2007
    24
    Great, thanks a lot!
  6. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Are you getting multiple lines working with 1 plan? I thought I called them and they didn't offer that. Which plan do you have?
    Thanks,
  7. nmangaoang
    Jun 22, 2007
    35
    Hi Rob,
    I think that's the Call Waiting feature from Broadvoice. It lets you accept incoming call even when you're on the phone.
    Nick
  8. emerbrito
    Oct 24, 2007
    24
    Hi Rob;
    I have the Unlimited World Plus.
