1 Way Audio After Queue
Discussion in '3CX Phone System - General' started by kduncan, Nov 13, 2012.
  1. kduncan
    Nov 13, 2012
    6
    We have calls sent to a ring group first. If there is no answer they go into a queue group. Any calls coming from the queue have 1 way audio where we can not hear the caller. If the call is answered while in the ring group there is no issue. Any idea what may be going on?
  2. kduncan
    Nov 13, 2012
    6
    We did more testing. If you answer the call out of the queue there is 1 way audio. If you place the call on hold after answering and then resume the call there is 2 way audio.... not making much sense... ideas?
  3. markshehan
    markshehan New Member
    Nov 14, 2012
    141
    It does make sense - but need to see your verbose logs to see why.
    When you make a call, transfers, music on hold etc. there is another invite involved each time. So an invite when moving from the queue to the extension is not correct (sending wrong audio information) but when you put them on hold another invite is sent, and then when you resume another invite is sent (all of which are correct - hence the audio).
    I would guess you have a queue setting wrong, but without the logs I am only guessing.
