1 Way Audio from external Extensions
Discussion in '3CX Phone System - General' started by yozh, Dec 16, 2010.
  1. yozh
    Dec 12, 2010
    8
    I have a brand new install of 3cx on a public IPed server, direct connect no NAT etc. here is the log when even calling 999
    Single NIC, latest updates on 3cx, OS is XP Pro
    Code:
    16:04:04.140
    [CM503008]: Call(1): Call is terminated
    16:03:59.484
    Currently active calls - 1: [1]
    16:03:56.640
    [CM503007]: Call(1): Device joined: sip:999@127.0.0.1:40600;rinstance=19cf5c2121a5a13f
    16:03:56.625
    [CM503007]: Call(1): Device joined: sip:300@XX.XX.144.105:60174
    16:03:56.609
    [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:999@127.0.0.1:5060]
    16:03:56.609
    [CM503002]: Call(1): Alerting sip:999@127.0.0.1:40600;rinstance=19cf5c2121a5a13f
    16:03:56.109
    [CM503025]: Call(1): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=19cf5c2121a5a13f]
    16:03:56.078
    [CM503004]: Call(1): Route 1: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=19cf5c2121a5a13f]
    16:03:56.000
    [CM503010]: Making route(s) to "999"<sip:999@XX.XXX.119.154>
    16:03:55.921
    [CM505001]: Ext.300: Device info: Device Identified: [Man: Counterpath;Mod: eyeBeam;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [eyeBeam release 1104g stamp 54685] PBX contact: [sip:300@XX.XX.119.154:5060]
    16:03:55.828
    [CM503001]: Call(1): Incoming call from Ext.300 to "999"<sip:999@XX.XX.119.154>
    16:03:51.484
    [CM504001]: Ext.300: new contact is registered. Contact(s): [sip:300@XX.XX.144.105:60174;rinstance=081ac4becc58b62a/300]
    16:03:51.031
    [CM504002]: Ext.300: a contact is unregistered. Contact(s): []
    16:03:50.593
    [CM504001]: Ext.300: new contact is registered. Contact(s): [sip:300@XX.XXX.144.105:16394;rinstance=62e8b3d499ffbc9f/300]
    15:46:32.796
    [CM504001]: Ext.IVRForward: new contact is registered. Contact(s): [sip:IVRForward@127.0.0.1:40600;rinstance=7154f42fa00a2d2b/IVRForward]
    15:46:32.796
    [CM504001]: Ext.EndCall: new contact is registered. Contact(s): [sip:EndCall@127.0.0.1:40600;rinstance=64c8069aef4e9ca8/EndCall]
    15:46:32.703
    [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:999@127.0.0.1:40600;rinstance=19cf5c2121a5a13f/999]
    15:45:35.328
    [EC200006]: Conference server is connected: application:papad:0/3CXConferenceRoom local:127.0.0.1:5482 remote:127.0.0.1:3172
    15:45:31.031
    [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*1@127.0.0.1:40000;rinstance=024c352cd0c5479b/*1]
    15:45:31.031
    [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*0@127.0.0.1:40000;rinstance=4abefd584affd912/*0]
    15:45:31.000
    [CM504001]: Ext.*777: new contact is registered. Contact(s): [sip:*777@127.0.0.1:40000;rinstance=2eac889031f9b4fb/*777]
    15:45:29.859
    [EC100007]: External application is connected: application:papad:0/QueueManager local:127.0.0.1:5482 remote:127.0.0.1:3170
    15:45:24.156
    [CM504008]: Fax Service: registered as sip:888@XX.XX.119.154:5060 with contact sip:888@XX.XXX.119.154:5100;user=phone
    15:45:21.031
    IP(s) added:[XXX.XX.119.154]
    15:45:19.625
    [EC200004]: IVR server is connected: application:papad:0/IVRServer local:127.0.0.1:5482 remote:127.0.0.1:3163
    15:45:17.031
    [EC200005]: Parking Orbit server is connected: application:papad:0/3CXParkOrbit local:127.0.0.1:5482 remote:127.0.0.1:3161
    15:45:13.796
    [EC200002]: Media server is connected: application:papad:0/MediaServer local:127.0.0.1:5482 remote:127.0.0.1:3158
    15:45:12.765
    [CM506002]: Resolved SIP external IP:port (XX.XX.119.154:5060) on Transport XX.XX.119.154:5060
    15:45:12.734
    [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport XX.XX.119.154:5060
    15:45:11.015
    Failed to obtain short path name for [C:\Documents and Settings\All Users\Application Data\3CX\Bin\Cert]
    15:45:11.015
    [CM501006]: Default Local IP address: [XX.XX.XX.XX]
    15:45:11.015
    [CM501007]: *** Started Calls Controller thread ***
    15:45:11.015
    [CM501002]: Version: 9.0.15516.0
    15:45:11.000
    [CM501001]: Start 3CX PhoneSystem Call Manager
    15:45:09.906
    [EC200001]: Configuration server is connected: application:papad:5485/DBProvider local:127.0.0.1:3156 remote:127.0.0.1:5485
    10,368
    229
    What sort of router/firewall is extension 300 behind? If calls to 3CX VM get no audio then it would tend to point to something (router) at the remote end not allowing the voice packets to get through. Could it be because those port numbers are forwarded to another device on the network?
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Verbose log provides more information. It is recommended to set it on Settings->Advanced page of management console and then restart 3CX PhoneSystem service.
    1. Try to connect 3CX Phone instead of x-lite. In account configuration set "I'm out of the office" and specify IP of PBX. Does 3CX Phone receive audio? If 3CX Phone has no problems then you need to check x-lite settings.
    2. If 3CX Phone also has the same problem then try to set ALLOWSOURCEASOUTBOUND parameter (in PBX configuration) to 1. This parameter is described in release notes for SP5 (you can find it on 3cx.com/blog)
    I think that ALLOWSOURCEASOUTBOUND=1 will resolve problem but it may cause problems in some call scenarios. I would like to recommend either to check NAT device (router/firewall) configuration on remote end or to use 3CX Phone connected through the tunnel.
  4. yozh
    Dec 12, 2010
    8
    Thank you will try that. The issue comes from soft phones on iPhone via 3G 3GS or other soft phones don't work and I can't change any settings in Att network will try to change the setting you mentioned. Thank you.
  5. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Can you test on a remote softphone on a PC instead of from the iPhone? Does the iPhone work on WiFi?
  6. yozh
    Dec 12, 2010
    8
    Everywhere I tested it didnt work. I didnt get a chance to make the change yet. I will later today and report with the results
  7. yozh
    Dec 12, 2010
    8
    Ok tested again from a remote location with x-lite phone again with changed setting same issue. Used 3CX iphone client same issue.
    here is the log:
    Code:
    15:05:47.515  Currently active calls [none]
    15:05:17.500  Currently active calls [none]
    15:04:45.500  Currently active calls [none]
    15:04:33.656  [CM503008]: Call(3): Call is terminated
    15:04:29.390  [MS210005] C:3.1:Answer provided. Connection(proxy mode):xx.xx.119.154:7006(7007)
    15:04:29.390  [MS210001] C:3.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40612(40613)
    15:04:29.375  Remote SDP is set for legC:3.2
    15:04:29.187  [MS210004] C:3.2:Offer provided. Connection(proxy mode): 127.0.0.1:7008(7009)
    15:04:29.156  [MS210000] C:3.1:Offer received. RTP connection: xx.xx.139.2:4786(4787)
    15:04:29.156  Remote SDP is set for legC:3.1
    15:04:28.875  Session 39 of leg C:3.1 is confirmed
    15:04:18.453  [CM503007]: Call(3): Device joined: sip:999@127.0.0.1:40600;rinstance=ed77b79f7a4da4d9
    15:04:18.421  [CM503007]: Call(3): Device joined: sip:300@166.137.139.2:4755
    15:04:18.406  [MS210005] C:3.1:Answer provided. Connection(proxy mode):xx.xx.119.154:7006(7007)
    15:04:18.390  [MS210001] C:3.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40612(40613)
    15:04:18.375  Remote SDP is set for legC:3.2
    15:04:18.296  [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:999@127.0.0.1:5060]
    15:04:18.296  [CM503002]: Call(3): Alerting sip:999@127.0.0.1:40600;rinstance=ed77b79f7a4da4d9
    15:04:18.109  [CM503025]: Call(3): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=ed77b79f7a4da4d9]
    15:04:18.109  [MS210004] C:3.2:Offer provided. Connection(proxy mode): 127.0.0.1:7008(7009)
    15:04:18.046  [CM503004]: Call(3): Route 1: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=ed77b79f7a4da4d9]
    15:04:18.031  [CM503010]: Making route(s) to <sip:999@xx.xx.119.154>
    15:04:18.015  [MS210000] C:3.1:Offer received. RTP connection: xx.xx.139.2:4786(4787)
    15:04:18.000  Remote SDP is set for legC:3.1
    15:04:18.000  [CM505001]: Ext.300: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for iPhone 1.0.18] PBX contact: [sip:300@xx.xx.119.154:5060]
    15:04:17.984  [CM503001]: Call(3): Incoming call from Ext.300 to <sip:999@xx.xx.119.154>
    15:04:17.968  [CM500002]: Info on incoming INVITE:
      INVITE sip:999@xx.xx.119.154 SIP/2.0
      Via: SIP/2.0/UDP xx.xx.139.2:4755;rport=4936;branch=z9hG4bKPj2BGmKsIALjsEENm5ZXnmtXv5Tm0V7isF
      Max-Forwards: 70
      Contact: <sip:300@xx.xx.139.2:4755>
      To: <sip:999@xx.xx.119.154>
      From: <sip:300@xx.xx.119.154>;tag=XkYIzjQAkghr5gk54moFFPEnp-et1alD
      Call-ID: 3f6aYP0UHh4XmbNKJyi7MZDQch9G6.-w
      CSeq: 23332 INVITE
      Session-Expires: 1800
      Min-SE: 90
      Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
      Proxy-Authorization: Digest username="300",realm="3CXPhoneSystem",nonce="414d535c031c533e67:225b50d2f07fa84d174acb35af9f6caf",uri="sip:999@xx.xx.119.154",response="d874808f9e8c5cb30683c8a1ba07d203",algorithm=MD5
      Supported: replaces, 100rel, timer, norefersub
      User-Agent: 3CXPhone for iPhone 1.0.18
      Content-Length: 0
    15:04:13.500  Currently active calls [none]
    15:03:52.984  [CM504001]: Ext.300: new contact is registered. Contact(s): [sip:300@xx.xx.144.105:1393;rinstance=420e205f11ed05b9/300,sip:300@xx.xx.139.2:4755/300]
    15:03:41.500  Currently active calls [none]
    15:03:09.484  Currently active calls [none]
    15:02:37.484  Currently active calls [none]
    15:02:27.812  [CM503008]: Call(2): Call is terminated
    15:02:15.265  Session 31 of leg C:2.1 is confirmed
    15:02:15.078  [CM503007]: Call(2): Device joined: sip:999@127.0.0.1:40600;rinstance=ed77b79f7a4da4d9
    15:02:15.046  [CM503007]: Call(2): Device joined: sip:300@xx.xx.144.105:1393
    15:02:15.031  [MS210005] C:2.1:Answer provided. Connection(proxy mode):xx.xx.119.154:7002(7003)
    15:02:15.015  [MS210001] C:2.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40610(40611)
    15:02:15.000  Remote SDP is set for legC:2.2
    15:02:14.968  [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:999@127.0.0.1:5060]
    15:02:14.953  [CM503002]: Call(2): Alerting sip:999@127.0.0.1:40600;rinstance=ed77b79f7a4da4d9
    15:02:14.718  [CM503025]: Call(2): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=ed77b79f7a4da4d9]
    15:02:14.703  [MS210004] C:2.2:Offer provided. Connection(proxy mode): 127.0.0.1:7004(7005)
    15:02:14.625  [CM503004]: Call(2): Route 1: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=ed77b79f7a4da4d9]
    15:02:14.593  [CM503010]: Making route(s) to "999"<sip:999@xx.xx.119.154>
    15:02:14.593  [MS210000] C:2.1:Offer received. RTP connection: xx.xx.144.105:62210(62211)
    15:02:14.578  Remote SDP is set for legC:2.1
    15:02:14.562  [CM505001]: Ext.300: Device info: Device Identified: [Man: Counterpath;Mod: eyeBeam;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [eyeBeam release 1104g stamp 54685] PBX contact: [sip:300@xx.xx.119.154:5060]
    15:02:14.531  [CM503001]: Call(2): Incoming call from Ext.300 to "999"<sip:999@xx.xx.119.154>
    15:02:14.500  [CM500002]: Info on incoming INVITE:
      Via: SIP/2.0/UDP xx.xx.144.105:47509;branch=z9hG4bK-d8754z-ce54ea695e827115-1---d8754z-;rport=47509
      Max-Forwards: 70
      Contact: <sip:300@xx.xx.144.105:1393>
      To: "999"<sip:999@xx.xx.119.154>
      From: "xx.xx.119.154"<sip:300@xx.xx.119.154>;tag=6cdd7f5e
      Call-ID: ZjRhNTVmZTBiOGY2NmNlNDBhNTE2YWY5YzMyOTNlMTU.
      CSeq: 2 INVITE
      Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
      Proxy-Authorization: Digest username="300",realm="3CXPhoneSystem",nonce="414d535c031c52c632:fc4dc3ccdd1770e22b3d1b9f31dfa857",uri="sip:999@xx.xx.119.154",response="fedc3124505d55fa16f22c98afcb374e",algorithm=MD5
      User-Agent: eyeBeam release 1104g stamp 54685
      Content-Length: 0
    15:02:07.390  Currently active calls [none]
    15:01:40.593  [CM504001]: Ext.IVRForward: new contact is registered. Contact(s): [sip:IVRForward@127.0.0.1:40600;rinstance=926943f6a887de24/IVRForward]
    15:01:40.453  [CM504001]: Ext.EndCall: new contact is registered. Contact(s): [sip:EndCall@127.0.0.1:40600;rinstance=7851d142fa461975/EndCall]
    15:01:40.281  [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:999@127.0.0.1:40600;rinstance=ed77b79f7a4da4d9/999]
    15:01:35.390  Currently active calls [none]
    15:01:34.171  [CM503020]: Normal call termination. Reason: Not available
    15:01:34.171  [CM503016]: Call(1): Attempt to reach "999"<sip:999@xx.xx.119.154> failed. Reason: Not Registered
    15:01:34.031  [CM503016]: Call(1): Attempt to reach "999"<sip:999@xx.xx.119.154> failed. Reason: Not Registered
    15:01:34.031  [CM503017]: Call(1): Target is not registered: Ext:Ext.999
    15:01:34.031  [CM503010]: Making route(s) to "999"<sip:999@xx.xx.119.154>
    15:01:34.031  [MS210000] C:1.1:Offer received. RTP connection: xx.xx.44.105:51026(51027)
    15:01:34.015  Remote SDP is set for legC:1.1
    15:01:34.015  [CM505001]: Ext.300: Device info: Device Identified: [Man: Counterpath;Mod: eyeBeam;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [eyeBeam release 1104g stamp 54685] PBX contact: [sip:300@xx.xx.119.154:5060]
    15:01:33.890  [CM503001]: Call(1): Incoming call from Ext.300 to "999"<sip:999@xx.xx.119.154>
    15:01:32.468  [CM500002]: Info on incoming INVITE:
      Via: SIP/2.0/UDP xx.xx..144.105:47509;branch=z9hG4bK-d8754z-4a1fd02065cbaa51-1---d8754z-;rport=47509
      Max-Forwards: 70
      From: "69.123.119.154"<sip:300@xx.xx.119.154>;tag=d510e62f
      Call-ID: N2UxMTA1ODQwMzM3N2Y5MGY3ZmM4OGNjZGI3YWY3YjM.
      CSeq: 2 INVITE
      Proxy-Authorization: Digest username="300",realm="3CXPhoneSystem",nonce="414d535c031c529c21:f23c7b5c5c1caa65aededd38abb3b8d8",uri="sip:999@xx.xx.119.154",response="980d823e7fb32fa7afe6570bba1e0759",algorithm=MD5
      Content-Length: 0
    There is no 3CX for Mac the softphone that is, so I can try it.
