10.3:No pop-up notification above taskbar on ring group call
Discussion in '3CX Phone System - General' started by r2k, Oct 4, 2011.
  1. r2k
    r2k
    Jan 9, 2011
    23
    Hi folks,
    I recently updated my 3cx to 10.3. I recognized that this helpful popup above the taskbar is no longer showing when a call comes from a ring group. If I get an direct call its showing up as it should. This was no before 10.3 so this might be a feature or a bug :)
    I reinstalled myphone on my pc but it did not change. The settings “Bring to front” and “Notify incoming calls” are checked.
    Has someone the same issue?
    Best regards
    Marco
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    Re: 10.3:No pop-up notification above taskbar on ring group
    http://3cx.ideascale.com/a/dtd/Pop-up-incoming-call-from-call-queue/305963-9854
    i suggest this when i see like you that this feature is deleted since last sp.
  3. r2k
    r2k
    Jan 9, 2011
    23
    thanks for your replay. Important for me: not a issue on my box :)
    I've agreed your vote!
  4. anatek
    Oct 24, 2011
    I have the same problem (Win 7sp1 / 3CX 10.3)!
    Sometimes appear, sometimes not appear pop-up notification when a call come in and I don't find any logic. I try all possible combination from MyPhone Preferences (Bring to front on incoming call...), I can't use all time - Notify external program on incoming call. Thanks for any help!
  5. Eunan
    Dec 12, 2011
    Hi, Running 3CX on a windows professional machine and there is no pop up when there is an incoming call. This is a real pain. Is there anyway to sort this out?
    Cheers, Eunan.
