10 digit default password
Discussion in '3CX Phone System - General' started by moshes, Apr 25, 2007.
  1. moshes
    Apr 25, 2007
    I am trying to define extentions and no matter what I type in the password window of the PBX definition, it defaults to a 10 chars (unseen) default (such as "**********")
    HELP :)
    Thanks.
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    The interface displays 10 "*" for security reasons
    The whole point of using "*" when displaying a password field is so nobody can see your password.
    If the field shows "***" for a 3-character password, it's possible to break in using a brute-force attack with 1000 attempts. This way, we hide not only the content, but also the length.
    It's just common sense security.
    If you input a 4-char password, it will be stored correctly.
  3. moshes
    Apr 25, 2007
    Pls have the manual say something as to the 4 char requirement.
    Again thank you.
