10 minute reconnect trunk delay after Internet outage
Discussion in '3CX Phone System - General' started by mbabs1, Feb 8, 2012.
  1. mbabs1
    Feb 8, 2012
    It currently takes 3 cx ten minutes to reregister my trunk after Internet outage does anyone know how to make this faster or instant? Happens 5 times a day always takes exactly 10 minutes to reregister
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    This is the default timeout between registration attempts. You can change this from VoIP Providers, select your trunk, go to Advanced tab and modify field "Time between registration attempts (seconds)". You will see there 600 the default value.
