13. Outbound Rules - routing outgoing calls
Discussion in '3CX Documentation' started by Katerina, Jan 26, 2017.
  1. katerinaK
    3CX Support
    Feb 24, 2016
    40
  2. Belhocine Mustapha
    May 27, 2018
    Hello ,
    I have configured a Patton smatnode 4114 as voip Gateway to PSTN, I followed the 3CX wizrd and I got the config file that I load it to my patton:
    - The patton is registred , in the sip trunks I can see the green bullet beside the name of the Gateway
    - I am able to receive calls to the extension defined in the 3CX but I can make call to the external PSTN through my extension, eventhough I have defined an outband rules
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,888
    321
    Hello @Belhocine Mustapha
    As a first step make sure that the outbound rules are configured correctly and that they match the call you are trying to make.
    Also make sure that you are dialling the number in the correct format.
    Check the activity log of the PBX for any errors that might indicate the reason the calls are failing.
  4. Belhocine Mustapha
    May 27, 2018
    Indeed I have errors, I think it' related to Patton
    somehow there is a time out
    I uploaded a print screen of the error, can you supoort what the root cause of that?
  5. YiannisH_3CX
    May 10, 2016
    4,888
    321
    What firmware version is your Patton running? Make sure that you are running the supported one.
    You could also run a wireshark capture to determine where the error is coming from.
