14. Connecting 3CX Phone Systems (Bridges)
Discussion in 'Documentation' started by Katerina, Jan 26, 2017.
  1. katerinaK
    3CX Support
    Feb 24, 2016
    42
  2. jeffvz@gmail.com
    Feb 19, 2016
    9
    I'm using V15 SP4 and 5. These instructions were incomplete for me. I had to add an Outbound Rule in the normal Outbound Rules tab. I created a new rule and put the same prefix number I used in the bridge creation, in the "Numbers with prefix" line. Then had to select the bridge as an Outbound route and strip the first digit. Had to do this on both ends to make it work. Else it just dies or tries to make Outbound call on the other system.
  3. nickybrg
    nickybrg Support Team
    Jun 7, 2007
    2,002
    104
    We have updated it - thanks for the heads up on this one!!
  4. Damijan A.
    May 11, 2017
    Hello.
    We are building a branch Office and would like to connect their 3CX sistem via bridge with ours.
    We have a VPN site-to-site connection.
    The instructions say:
    Step 2: Create a Bridge on the Slave Phone System
    In the remote PBX section, enter the Public IP or FQDN of the “Master” 3CX Phone System and the port (default 5060).
    Can you please confirm that the private IP address will work (since it is a VPN connection and the systems can see eachother with private IP), or is it mendatory to connect via public IP (which is defined under NETWORK -> Static Public IP (IP Address does not change)).
    Thanks in advance.
  5. nickybrg
    Jun 7, 2007
    2,002
    104
    Yes if you have a vpn, then you can put the local ip. It will work.
  6. Damijan A.
    May 11, 2017
    Thank you for the quick answer and great service.
