14 SP2 upgrade problems
Discussion in '3CX Phone System - General' started by WaltDjr, Dec 15, 2015.
  1. WaltDjr
    Dec 15, 2015
    I’m in the process of doing a proof of concept using 3cx. After upgrading to 14 SP2 and I try to restore the backup from either 14 or 12.5, it says it has to restart the services and once I click ok it goes back to the login screen. No services are restarted and the installation is still a fresh install. Any suggestions?
    Thanks in advance,
    WaltDjr
  2. WaltDjr
    Dec 15, 2015
    Ok, I think I've narrowed down that it has to do with getting 404 messages when trying to restart services. Still any suggestions are welcomed.
  3. WaltDjr
    Dec 15, 2015
    OK, after researching even more, I finally found this post. http://www.3cx.com/forums/#p174159
    This also fixed my issue.
    Uninstall previous version.
    REBOOT
    then install new version.
