Solved 15.1.41 Unclear connection status
Discussion in 'Android' started by Thomas Michel, Sep 4, 2017.
  1. Thomas Michel
    Sep 4, 2017
    I have a question regarding the 3CX Android App. I added a screenshot for clarity:
    [​IMG]
    The status seems to be 'Disconnected', but I am able to call internally another number successfully (I haven't set up a trunk for external calls, yet...). It is also possible to call my number successfully.
    Can someone give me a hint what this status is about?
    My setup:
    3CX (15.5.5) in DMZ, Port 5060 (tcp and udp) towards 3CX is open from internal network.
    Samsung phone
    Android 6.0.1
    App version 15.1.41
    Thanks!
    Best regards,
    Thomas
    PS: Same behaviour with App on an iPhone
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    Port 5001/443 Myphone port is likely unreachable due to it being closed. Give it a check.
  3. Thomas Michel
    Sep 4, 2017
    Leonidas,
    That did the trick! Thanks!
    Best regards,
    Thomas
  4. ZacSC
    Jan 21, 2016
    16
    I am having this same issue but only on our internal network. Are you able to explain this a little more? What do you mean by it being closed?
  5. Thomas Michel
    Sep 4, 2017
    ZacSC,
    On the firewall which connects the internal network with the DMZ, I needed to open port 5001 from internal network (where the phone is located) towards the DMZ (where the 3CX is located).
    If your 3CX and the phone are already in the same network: Is there maybe a firewall on the machine where the 3CX is running which blocks port 5001?
    Thomas
  6. ZacSC
    Jan 21, 2016
    16
    Thanks for replying Thomas. I am actually not sure what was wrong, after upgrading to v15 seemed like my Android phone did not work to get presence and showed disconnected but everything else worked fine.
    I finally just rebooted everything and not its working.
  7. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    13
    Hello @ZacSC
    Run the Firewall checker on the PBX and check if something else is blocked.
    Thank You
