Solved 15.5 Hotel Features not showing up.
Discussion in '3CX Phone System - General' started by lvhotel, Jun 11, 2017.
  1. lvhotel
    May 18, 2016
    5
    *solved* Install 15.5 then back then reinstall.
    I just updated to the 15.5 version from 14 (had to wait for hotel features) and the hotel features aren't showing.
    Has anyone else run into this? I'm wondering if there is a remnant in the backup file that I use from all the upgrades we've done over the last couple years, in the parameters or some where that is prohibiting it from showing. Or if it is a license issue.
    My license shows I am a licensed using a pro version. My maintenance shows expired at 3 am today, but I switched to the annual license when offered a free year so my license is still valid.
    #1 lvhotel, Jun 11, 2017
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    763
    39
    What I have noticed is that the Hotel Feature only showing up if the PBX is running on Linux. It is not showing up if the PBX is running on Windows. NFR license or not.
    lvhotel likes this.
  3. lvhotel
    May 18, 2016
    5
    I was wondering about that. I spun up a free cloud one and it was there.
    I guess I'll have to look at switching to a linux version.
  4. jed
    jed New Member
    Feb 1, 2010
    138
    41
    We fixed it.. and is still on Windows.
    We made a backup of our installation, uninstall and make a new install using our Backup.
    Reason, some modifications made to the DB that is not set during our upgrade..
    Hope this will help..
    tvdir, fmtech1 and lvhotel like this.
  5. lvhotel
    May 18, 2016
    5
    Sounds like an easier process than moving to a linux box. I'll give it a try
  6. 3ctech
    Apr 29, 2014
    7
    I can confirm a backup and reinstall corrects the hotel module not showing up on windows.
  7. jed
    jed New Member
    Feb 1, 2010
    138
    41
    You might have to change the Windows / 3CX Service 3CXHotelModule01 from Disabled to Automatic startup.
  8. StefanW
    Jun 2, 2009
    1,210
    85
    Only for windows install you must do the reinstall via a backup and restore as additional services need to be installed. In Linux this does not apply as the hole package is replaced each time an update is performed.
    To add, the same applies for the music play list service. Windows needs the reinstall...
  9. jem1
    Aug 29, 2012
    79
    30
    So why was this not highlighted anywhere that both require a re-install on Windows and is there any other features in 15.5 that require the reinstall? I was going to simply do a normal update for a customer soon for the playlist feature and would have been fairly upset if I had to spend hours figuring out why it was not there.
  10. Tony Cave
    Jun 8, 2017
    25
    We are running our NFR licence upgraded to 15.5.5 on Debian on AWS and no hotel features are showing since the upgrade either....
  11. StefanW
    Jun 2, 2009
    1,210
    85
    I am with you on this. The relevant departments have been informed to put this out there in an easy to find manner...
  12. jem1
    Aug 29, 2012
    79
    30
    Stefan, thank you! I had asked about upgrade options during the live launch and it was stated that 15.5 was the first major version that could be upgraded via the console but they didn't mention the Hotel or Playlist not working! :) Glad I check the forums regularly and do small rollouts before doing most of our customers that will let us update them.
  13. fmtech1
    Jun 22, 2017
    Brilliant! Saved me quite the troubleshooting headache :)
    Hopefully they will remove the need for a reinstall in the next SP.
