Solved 15.5 SP2 Won't Update
Discussion in '3CX Phone System - General' started by Stuart Mitchell, Dec 1, 2017.
  1. Stuart Mitchell
    Dec 1, 2017
    5
    I have been trying to update our system to the latest version (15.5 SP2), but when I click "Download Selected", and I accept the warning that says services will be stopped during the update, etc, it then takes me back to the 3CX login page and doesn't apply the update.
    I've tried this several times since the update was released.
    Any idea what might be causing this? All other updates are up-to-date in 3CX.
  2. Stuart Mitchell
    Dec 1, 2017
    5
    In the process of testing the "Auto Update" feature. Will post results.
  3. Stuart Mitchell
    Dec 1, 2017
    5
    Okay, 3CX server rebooted, but the Update is still sitting there waiting to be installed. How can I check the current version in the 3CX console?
  4. Stuart Mitchell
    Dec 1, 2017
    5
    Okay, just ran a manual backup (which shows the Version), and it's still 15.5.3849.1.
    Please let me know how I can either manually install SP2, or diagnose why it's not installing.
  5. StefanW
    Jun 2, 2009
    1,222
    93
    windows or linux?
    if linux, can you run apt-get update. Do you get any other errors?
    Which repo do you use? cat /etc/apt/sources.list.d/3cxpbx.list
  6. Stuart Mitchell
    Dec 1, 2017
    5
    Linux, but looks like our company director got it upgraded over the weekend.
    Thanks for the advice anyway :)
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,341
    535
    Glad the issue has been resolved
