15 Config - DNS
Discussion in '3CX Phone System - General' started by ian.watts, Oct 4, 2016.
  1. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Is there a method to change a chosen option to use a single FQDN to instead avail the Internal FQDN/IP and External FQDN instead without backup/reinstall?
    I apparently derped on this last install.. assumed there was some local/internal DNS host available.. there isn't.
    Can I adjust custom params for this? If so.. let's assume I'm happy with the external FQDN (I am..) and need a local IP (since again I don't have local DNS..).
    I ask because it ties into the next possible question about re-using one of those issued Let's Encrypt certificates.. I'm afraid I won't be able to use the same host name if I retried the install without calling support.. and unsure even if then.
    On this bit.. I'll be pursuing the CSR/PFX option.. but also have a question out about replace/renew on those (three years can go by fast..). Else.. I'd just have backed up and done over with changing that DNS question accordingly..
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    563
    Hi there,
    I am afraid the solution to your problem is un-install and re-install. Assuming we are talking about V15 form the question you need to perform a backup without including license information and FQDN. Un-install restart the windows machine and re-install.
    When you are asked for a key use the same you had before and when asked if you want a 3Cx FQDN or your own choose a 3CX one and choose the same hostname as before. You will be able to pick the same hostname as it is bound to your license.
  3. ian.watts
    Apr 8, 2011
    532
    Indeed, thank you.
    The bigger concern was the 3cx.us certificate and possibly not being able to reuse it upon reinstall. Good to know it binds to the license. Makes sense, given it is also renewed with current maintenance. :)
